Richard VIALLE's new theory about negative mass and overunity
Started by Pascuser, August 28, 2012, 07:03:17 PM
Khwartz
@Pascuser
Dear Pascal, if you come around, I would like to inform you that since yesterday I am no more able to post nor to send any PM in our forum in Conspirovniscience.com.
I have tried to unlog and inlog but couldn't inlog back, the page saying I had not the right secret code (for sure I had indeed).
I have asked for a new code but didn't receive anything, could you do something about? I would like to thanks you all for your last answers but still would appreciate if you could, all you guys, check and complete my list of items of specifics for replication, the one at the time "Lundi 20 Janvier 2014 à 15h35" [Monday 20th January, 3:35 pm], so that I could translate and publish it here to give the data for a "state of the art" replication here.
@Woppy
You had started to replicate in English, so I know you have some skills in English: wouldn't be a nice idea if you could complete the publication of your replication here? You have already all the materials for, I suppose, like pics and schematics ;)
Regards.
tim123
Hi Folks,
  I've just found this thread. Never heard of Richard Vialle before...
Has anyone proposed a mechanism / a principle of operation for the aUto-Generator? It's an interesting design...
I.e. how does the magnetic field cause the electrostatic effect? Is it simply the 'left-hand-rule'? Are the 2 halves of the U acting as halves of a dipole antenna?
I'm interested in finding out more about the 'Pigtail' device. From what I can tell - it has gravity modifying properties, and that's something i'd like to work more on...
Can anyone elaborate on the pigtail device? Pascal has this page, but it's not very easy to follow in Google Translate:
http://jnaudin.free.fr/rvproject/html/pascuser_rep4.htm
I notice that his resonance is at 155Mhz - which would be far too high for my test equipment. I would have to make a much bigger coil...
I wonder - is it possible / worthwhile - making a 3-layer pigtail coil...? (I have a theory about higher dimensions & spirals...)
i.e, something like this:
- Layer 1 - magnet wire wound on 16Amp house cable
- Layer 2 - result of above wound on 16Amp house cable
- Layer 3 - result of above wound on copper/plastic pipe
Regards, Tim
Khwartz
Hi tim123! Welcome on this thread to present the "how to do" of Richard's AutoGen.
The to halves are here to avoid what we call "hot current".
The "hot current", for Richard, is let's say "the ordinary current", the one we are used to use and think with.
It is said "hot" in opposition of "cold current".
The "hot current" is mostly known as a displacement of electrons from a nucleus to an other and called "free electrons", while the "cold current" is presented as the result of change of shape of the electron cloud around the nucleus.
Richard has calculated a frequency where we should couple with a frequency particular to the electron.
While we push this frequency by an outside excitation, we are supposed to increase the diameter of the electronic cloud by an increase of the amplitude of the waves made by the electrons around the nucleus. (The more than ten steps of test of JNL are said to verify the theory, as the power obtained out of the U shape.)
This alternative movement roughly similar to a "hot" alternative (so the ordinary one), EXCEPT IT DOES NOT PRODUCE ANY JOULE EFFET,  so not generating any lose,  BECAUSE OF NO REEL DISPLACEMENT OF CHARGES, only a 3D deformation of the electronic cloud. (I will translate more precisely later the exact words of Richard).
To be honest in respecting the spirit of the work done in my country, I have to say that Richard does not claim having understood everything perfectly. But the fact is that he has produced a theory with which he was able to create experiences which demonstrate the workability apparently both in antigravity and in overunity, and in this both domains it has been been documented antigravity and overunity phenomenons.
Any way, if we are aware that the theory needs to be improved so that we can exactly predict what is going on, we do have a theory which looks able to predict and produce that kind of phenomenons. It is the job of the experimenters now to go further in the observation so that this same theory could be refined.
For antigravity properpies, as I know and until now, none are associated with the RAG, only the "Pigtail" device, that I am not a specialist.
If we break the way to RE-produce the global overunity of the RAG, I will probably translate few materials on the Pigtail device. But here, at the PROMTECNO association (means association for promotion of new and forgotten technology - PROMotion des TEChnologies Nouvelles et Oubliées) we have taken the rule to focus on 1 main project called "project 0", the one we have estimated the most promising of all apparatus in the free energy realm. So I will try to follow the same path here and encourage others to do the same.
Have I answered to your questions, dear tim123?
tim123
Thank you Khwartz. You've given me something to work with.  I'll read some more... :)
e2matrix
Just jumped in here so I'm not sure if this was completed yet but I decided to at least try to translate the rest of that document.   This is the original one Pascuser put up and I believe Khwartz translated the first 5 pages.   This is just a rough translation of the text without pictures or diagrams and no translation of the handwritten pages (last 2).   But it at least gives a rough translation of the next 12 pages or so.   This was done with Google translate:
