0 Members and 131 Guests are viewing this topic.
T-1000
Quote from: John.K1 on October 27, 2015, 04:20:25 PM
I am gonna run it to sweep all possibilities of frequencies and duty cycles and let it to plot the outputs. I will run it all day if need- no boder- I am gonna f... crack it down  :D
No need for hammer approach, the simplest way still is like it was in Dally circuit - https://www.youtube.com/watch?v=r9G1Plfob5U
Ruslan just showed 200+250W load bulbs fully lit from 24V ~= 1.3A power source and used nanosecond pulse generator instead of Tesla coil in the video.
John.K1
Quote from: T-1000 on October 28, 2015, 05:08:49 AM
Hi T1000. I remember Ruslan has said the Dally design works fine.
Interesting video.  At 0.46 he shows HV pover supply for for his Signal generator. It is maybe clever to not to use Tesla coil, rather some more efficient easely tunable HV unit? Maybe Mazzily+flybeck? Or I have a 10KV adjustable neon transformer or plasma ball HV unit. How would it be than with frequencies as they run pretty slow in KHz ranges?
We did see the video Tomtech put here some pages before - in that video you can also see the flybeck next to his Ruslan's replication. I was thinking to myself why is it there. Now I can guess why ;)
BTW- Hammer is fine. I am gonna hammer it to get out of my frustration from that unit :D
Thanks
Tomtech29
Quote from: NickZ on October 28, 2015, 01:27:23 AM
  Guys:
  Here's a video that I just made showing my current system and my struggles to tame the wild beast.
  [size=78%]video 2015 10 27 21 04 58 - YouTube[/size]
Thanks for presentations
I saw the effect as an induction coil connected to the same circuit 28 windings in parallel increasing the output capacity of the coil winding 28
-brightness does not affect whether it is turned on Karcher is a problem though when the core of the saturation you cross the threshold of the power supply capacity can suck over 12 Ampere.
But I do not understand where you got that high voltage neon lights when Karcher is off?
you need to check whether the Karcher there is no tension
Disconnect the two wires of the primary winding of the Tesla coil
how it is grounded one end and the other goes to the antenna is where there is a spark of this unusual explain why?
Tomtech29
Hi.
T-1000
Thanks
in this nicely made device driver once surprises me. Interestingly, once again, we see the band damping transistors IRFP260 ,varistor, capacitor and resistor, rectifier diodes and Zener diode...
High-voltage multiplier apparently requires quite a substantial part of energy generation BMF in this pulse transformer!
-Pay attention that conventional inwerter They consume much more energy from a power source (idle 1 Ampere did not die)!
if the resonator is powered from the same transformer, but from another tap of the coil?
capacitors can be seen in an LC circuit where the drive system ?
Tomtech29
Itsu see here: where the probe is placed into the pattern (as I said earlier impulses at the top of the LC sine) there is visible the thin wire without insulation (coil parallel resonance)
This time the reverse polarity (we will have to be careful not to burn the oscilloscope) :D
interesting design I wonder if this time will be something more is known fingers crossed
wrote competitor
Ето не может работать без индуктора и кратности качера. В этом я убедился. Я сдесь не вижу кратности частот?"
>It can not work without the inductor and the multiplicity Katscher. In this I am convinced. I'm here to see prices do not see a multiplicity of frequencies?<
This time we'll see what we paints
