0 Members and 18 Guests are viewing this topic.
itsu
Quote from: T-1000 on November 13, 2015, 04:58:51 PM
The transformer in the video had bucking coils in the primary and secondary - https://i.ytimg.com/vi/4Ucgue7eH_4/maxresdefault.jpg
on the transformer E core. The secondary coil had capacitor attached for freewheeling LC.
This is why he could run it on the higher frequency than you can expect.
For the Tesla coil in Ruslan's case it is similar case with top load coupling with grenade coil and ground termination over capacitance. So we can try to use it for the same spike generation as you get in nanosecond pulse generator.
Ok,  thanks, so its a totally different setup from Ruslans.
Itsu
itsu
Quote from: Jeg on November 14, 2015, 06:13:01 AM
Itsu :)
Inside the blue box at Allegan's circuit, I see that he is inputting to his mosfet driver a 5V pulse from 74hc132 while he is supplying his driver with 12V. Does this work right? I had experienced in the past a high temperature increase on the driver part due to difference between the driving voltage and its power supply voltage. Is that true or you don't experience any problem driving it this way?
Tnks
Hi jeg,
no, no problems noticed, the MOSFET driver runs on 12V taking its input pulse from the 74hc132 which runs on 5V.
Itsu
Bat1Robin2
Latest video.
The temporary battery shown starts the low powered oscillators. The hidden battery inside the pvc pipe powers the high power FET mosfets and bulbs. Then power from the output can then take over to power the low powered oscillators and the temporary shown battery can be removed. As soon as power to the oscillators is interrupted output stops. Why put the pvc pipe in a box?  Only one reason to keep the open ends from coming into view.
(strike 1)
Also this device was not in the open to eliminate close quarter coupling possibility from a nearby transformer.
(strike 2)
Also the ground wire was not verified as ground touching it proves nothing.
(strike 3)
He took the tesla antenna off because it was taking up too much room to fit in his small box and as he knows it serves no purpose anyhow.
If this works without fraud then mount it on clear plexiglas with full 360 views from all directions. also outside with ground clearly shown bare wire style. Then include run time that exceeds battery energy possibility. No boxes no bull.
If this is real,
There is no way this has been overlooked for 100 years. Think of the thousands of high efficiency switching power supplies being designed out there. Just like the animals evolve so has our electronics non will evolve to a point that they no longer need energy to operate. Only the movies and fake videos show the walking dead. Its common sense.
forest
Bat1Robin2,
No shit ! really ?!   :o  They have to stop selling heat pumps and photovoltaic panels - it must be black magic. There is no way this has been overlooked for 100 years.
T-1000
Quote from: Bat1Robin2 on November 15, 2015, 12:02:40 AM
Latest video.
You sure guy would spend hundreds of dollar on parts (which mostly are blown before demo) and years of overtime just to show fake? If yes, this forum is not for you as the life have lots of other important things where you can spend your time without wasting others.
