0 Members and 293 Guests are viewing this topic.
NickZ
  If that were the case, then just tune the device for lower frequency. But, that it not the case, that is just one of the effects of adding a ground line. And is why one needs to TUNE the device with the ground line attached.
  If you've never built any of these devices, you'll only be guessing at best.
  They have never said that they need an earth ground line just to lower the frequency.
If you think that that is not so, then please show some proof of that.
  The antenna is not "make the antenna longer".  I don't know what you mean by that, but, the ground line is made as long as the grenade's output coil, 37.5 to 40 meters long, depending on the exact size of the grenade's output coil.
They have not made the antenna coil longer, either. The antenna coil is made and wound using six turns, most always. Although it may also work using more or less turns. That I don't know, as I've only followed the instructions, as seen on their videos, and schematics.
dewetw
Just as a note on the self destruct / meltdown of self looped devices: From Ruslan's videos he makes it clear to use a regulated power supply, the kind that can take 90 - 260Vac on the input to always produce 12V. The output production is controlled by the input voltage used. Thus by having a constant input voltage you can limit the production to not run away.
Also it is an assumption that ou self-looped systems will "run away" to the point of self destruct. Certain components like ferite will saturate at some point and change its properties, aka change inductance value. If you have such an inducter in series with your main resonant coil it will detune the circuit away from resonance as the power/voltage increases and limit production in such a way.
On another note, I have attached a photo of a 0 - 48V, 0 - 5A home made psu for my experiments. It runs of to 12V bats in ser for 24V that is stepped up to 52V into a buck regulator. This will serve as an electrically isolated portable psu. Here it is running a 50W down lighter.
Also attached is my prelim design on using just one IC (SN74HC14N) to generate the clock, duty cyc, 180deg phase shift for the push-pull aswell as the pulse delay and duration for controlling the tesla HF coil pulse. Will let you know if it works.
PolaczekCebulaczek
QuoteIf you have such an inducter in series with your main resonant coil it will detune the circuit away from resonance as the power/voltage increases and limit production in such a way.
ahaa ,you are right, very interesting observation!
NickZ ,I was talking about extracting energy from atom is such a way that its not from radioactive decay, just extracting energy from electron orbiting around, simple EM energy, no alpha beta particles heavy shit, something that has never been done. However, if such a method (mixing volts amps? ) would exist then what would happen to atom if we slow down electron movement inside ? it would lose its mass? (mass converted to energy yet no radioactivity?!). Taking energy by radioactive decay is the brute force method, I was thinking about something more cleaver and subtle.
Extracting energy from ambient? so from what? bunch of atoms in air? aaa... mysterious cosmic rays? AFAIK T.Henry Moray (if his device was not an efficient radioactive battery/PSU activated by radio waves as some people claim) says that we just need a dam of some sort and put it in the way of cosmic rays/waves to slow them down to convert to EM energy, in Moray case it was a special diode made of some galena and something else, receiver for cosmic energy. The question is: can we build such a dam from EM waves by mixing them? how the cosmic energy interacts with weird grenade coils and kacher contraption?
NickZ
   Clever and subtle?
   Well, this is a very complicated subject, which I've already stated my thoughts on.
   There are over 2500 pages of theory concerning different peoples opinions, so I suggest to get up to speed on these things by reading the previous posts, if interested.
   It is not about extracting energy from matter (atoms, or it's electrons), but from the Aether, instead.
Aether is not a material substance, but is the cause and reason for the existence of all material things.
   If you think that you have a new clever and subtle idea, these threads are full of these kinds ideas, yet not a single working self running device from anyone here.  So, take your pick as to what you think is the best way to go.
   However, I suggest that you read up on Tesla, as these devices are based on his thoughts, concerning tapping this unseen  cosmic force, as also mentioned by Tariel Kapanadze, and several others that have produced several self running devices, which once started are needing no further man made input sources.
