0 Members and 97 Guests are viewing this topic.
Сергей В.
В чем фишка ??
The trick is in that - Aether or Ether has own Tunnel Barrier exactly like your wall in daily room. So to excite Aether or Ether you need to strike and make a hole in the barrier.
Aetheric Barrier is perfectly elastic like organic cell membrane but harder than any diamond. To break-down (to tunnel through that hole) you need very very sharp needle and very very speed needle. That needle is your Nano-Pulse or Pico-Pulse. To make aperture apart barrier with your needle you should have to find a way - find some buffer which can make that barrier as thin as possible to easy your needle to break through Aetheric Force Field which bring pressure to our coarse material world - our reality. Aetheric world is also meterial but with much higer energy levels and mucg higer frequency levels starting from sub atomic particles levels till massive interstellar objects in that space. It's a new dimension. Imagine it like a space which is always on the same distance from our 3D world and Aetheric world (space) get contain in our world but it is not part of our world.
Like a water in sponge. Our world is sponge.
The main proble is in that all dimesions ARE NOT INTEGERS like many think but Transcendental numbers in sense of dimensionality. Our dimesnion is not a 3 but 3.0017xxxxx......~ and numbers of dimensions (realities) are infinite.... same like a numbers of barriers between realities (dimensions).
What is a buffer and where toi find it. Imagine it like an Air Blob in deep water. As blob is bigger or is under great pressure inside - it can make much thinner Aetheric barrier or get a stonger influence on Aetheric Force field. Our buffer is a metal conductor. As little resistance conductor have - the biger influcence can make on barrier and make him thinner so our needle can drill through it with smaller energy.
This is main reason why Nikola Tesla have had very thick and massive conductor for his nano and pico pulses. Once when we got a drilled hole Aether respone trying to close that hole injecting very high energy level  - part of it go to closing a hole and bigger part eneter in our dimension and make a very strange things. For example cooling conductors like liquid nitrogen, make things levitate or make a giant thunders and flashes, or make some electricity in huge ammount making sub atomic elemental particles much higer oscillation etc.
Effect is like a tiny hole in a giant overflow diversion dam. To get much much more energy from Aether or Ether we need to drill as bigger hole as we can.  So our switch must have as bigger conducting surface as can. We drill Aether with high energy levels. For example using Kardo Sisoev, V. M. Efanov, A. F. and Belkin Very Powerful 80kV subnanosecond Pulser - The Peak Envelope Power can reach more than 10MWatt in subnanosecond time domain. This is unique toy we need to drill through Aether and take in new Reality - in Energetic sence not in spatial. Forget time travel if you don't want to desintegrate your body and essence "soul". Yes the soul is mortal not importal as all demonic religions on planet Midgard (Cosmic name of our planet) said. Billions years of evolution on different planets in our universe and one little mistake and your turn off yourself completely from all dimesnsions-realities.Remember Philadelphia Experiment made by main JEWISH ILLUMINATI CABAL scientist A. Einstain. Interesting thing he was also one of them ... Same Leviticus blood had been in his veins. About his soul thnik yourself. What if he was one of ALIEN KOSCHEY ?? Officer of Dark Forces ??
How much sailors and officers had vanished for all times from all dimesnions ?? And nobody had not been responsible for HIGH TECH MASSARCE !! AS USUALLY ON PRISON PLANET !!
Buffer and how to get it....
To get proper buffer we need to parallel great number of MOSFETS or IGBN transistors. We nned as smaller Rds or Rce as possible.
For example if we use 20th IRFP 240 MOSFETS in paralle with typical Rds 0,18 om we can get 9 mili om resistance or conductivity 111.1 Siemens conductivity.
The best will be if we get conductivity over 1000S or lower Rds in micro-om range.
Big problem here is Very Brutal Aether Response in form of "BACK-KICK" so transistors very easy go to trash after breaking DS of CG gates. Aviso have same proble so he constructed some kind of High-Voltage-High-Amperage multystage filter to stop making a trash from new and expensive components.
Edvin Gray have had the same problem so he made new type of High-Voltage-High-Amperage switch in for of his CSET Tube !!
Violent "BACK-KICK" effect had been occured in past,  many times when HIGH VOLTAGE DIRECT CURRENT GENERATORS had been turned on and off using very thich cooper bars and conductors !!
Once Tesla have seen the death of 18people in close proximity from Generator and Conductors. All of them had got a Radiant ray stroke. (18 or less but bigger than 10)
From that time he had started researching HV IMPULSE TECHNOLOGY which resulted in his Magnificiant Magnifying Transformer,  Tunguska Event and Planetary Free Energy Generator built by him in Wardencliff !! But All his science works have missed in some Undergorund vaults .... like for example one of biggest vaults in U.S. under the small tourist town known as Sausalito near San Francisko. Interesting ?? The best hidden base in U.S. under small fisherman town. Well i must idmit very very good idea ?? If you want to hide something put in front of people eyes and they will not seen anything !!
Tesla used Mercury for his high conductivity switch with very big conducting surface to get effect. And he had got it. Does we will ??
forest
Сергей В
;D ;D ;D  you take the cake
verpies, now you see a little more of Newton III law  ;)  action vs reaction
no law is broken, just external energy source which is always here (and in Sun also)
working on it (in theory works beautifully....)
bear in mind that every wheel of nature should be carefully balanced with load; put a big mass/energy in one point and you got precession and destruction, that is one supression ; why there are standards and you have to get license
fortunately nature has a lot of governors
dllabarre
T-1000
In this picture is L1 & L4 wound clockwise or counter-clockwise?
verpies
Quote from: forest on May 27, 2013, 03:55:37 PM
Verpies, now you see a little more of Newton III law  ;)
No. What are you referring to ?
itsu
I tried severall suggested modifications.
I changed the MOSFET from an IRF740 with Rds(on) = 0.5 Ohm to 2 x IRFP260 parallel with Rds(on) of 0.055 Ohm, meaning an effective Rds(on) of about 0.025 Ohm, but no noticable difference was seen.
I changed the capacitor from 600nF to 6nF, but else then that the spike peak was not flattopped anymore, no changes where seen.
I used instead of the transformer a TK/Akula-style tubular air-core transformer (80 turns primary), but my FG is unable to deliver enough power to this low resistance primary.
I like the peak detector circuit from Сергей В., not sure if there are better opamps available now, so need to do some digging here, suggestions welcom.
Regards Itsu
