0 Members and 257 Guests are viewing this topic.
Jeg
Quote from: GeoFusion on July 10, 2014, 12:39:50 PM
Check this out, this will help too.
Experiment guyz try these out. Only when you try you will find out why ;)
GF thanks for all this! Is the attached schematic the whole generator circuit? Doesn't need to introduce the high frequency component on the peaks of this high current sinus? Also the question is for your schematic. Doesn't need a higher frequency superposition?
Thanks again for what you are trying to do!
Jeg
NickZ
  For those that want into get into this "Impulse Technology" and want to wind a yoke core for your generator crt, here is a clear picture of the one that I made.
This one has a 6 turn primary, and 22 turn secondary. The 3 turn output coil (not shown), can be thicker wire gauge. It is wound on the gap or space on the yoke.
  I have also placed electric tape between the yoke halves.
  Here below is also the basic Mazilli crt diagram, if interested in going that route.
GeoFusion
Hi Guyz  :)
Something for you guyz to read, About Ruslan. Important
http://peswiki.com/index.php/OS:Russian_replications_of_Kapanadze_solid_state_circuit
Srry for the Typo's d3x0r. Guessing was using to much Dutch lately, makes me type differently my apologies.
  Void:
yes at the bottom you have the square wave driver circuit as you can see :).
Yes, one step up there too, to get 24Vdc, but the circuit can be build such a way that you could supply the MosFets and IGBT's of certain rating with 120Vdc or 220Vdc + ! Akula did use 300Vdc on his first Sqaur wave circuit with IGBTs.
I can some how share some Tesla coil schematics I used  but the bottom circuit can be used also to operate an  Solid State Tesla Coil.
The top part is Kacher Circuit, Tesla coil. it is a oscillator. Do not fully understand  why it's being used but I see that It amplifies the output and must somehow effect the other squar pulse field in such a way. works as a Disruptor
Yes :), this circuit I used completely. but did minor mods on the output winding, it's all experimental.
   Nick:
yes, somehow a scope is needed, but it will eventually come. I could sometime borrow one from a friend, but fragile instrument.
Saw your pic of the coiling :),
Your Kacher tesla coil looks good but you will need to change the Primary thick coil with a smaller gauge wire.
and the output where induction is happening pulsed, you will need so see how many winds you'll need for your desired output voltage and amps. Your white and red coils I see there should be good gauge I guess.
Thick wire gauges  do play a important role for output amps at the output coil. take good look at akula videos.
Btw the yoke core's primary (white wire) is wrongly turned in the pic posted.
It's the same way how I've shown befor with the roundcore, it's only one direction and with center tap. :)
even the Mazilli circuit you re-posted you see where the 6 + 6 winds are at the flyback are one direction and center tap. that is how it should be wound for the yoke.
yes electrical tape or paper are in between the two halfs.
   Jeg:
No problem man :). this is the whole Generator circuit. But anyone can modify it, but It will be harder to Tune if you do.
The circuitry produces the High frequency and squar wave pulses for  the system to operate.
If you build it as you see on the schematic you will see.
Cheerz~
Grumage
Dear GeoFusion.
Am I correct in my assumption that you have succeeded in replicating the device that I was working with last year ??
https://www.youtube.com/watch?v=LOqjTHmmumU
Or are there some differences ?
My internal choke coil raised 10 Kv with the combined internal capacitor plates. And also held a single resonance frequency with regard to the primary induction coil that could be varied. I also tried the heating effect with a 1" ( 25 mm ) steel bar and this could not be touched by the hand within a minute !! It was this particular test that blew my IGBT's and at that moment in time blew my enthusiasm !!  :)
I look forward to your reply.
Cheers Grum.
Acca
 Ruslan generator new clip...
https://www.youtube.com/watch?v=tT9m6F53atk
schematic of  the coil...from  russian forum
http://www.realstrannik.ru/forum/39-kapanadze/134930-ustanovka-ruslana-kulabuxova.html?start=342
from youtube "leader jane" channel  who is making the Rusaln coil also..
https://www.youtube.com/watch?v=anvb_PXG1YA
https://www.youtube.com/watch?v=yKjgMmZcFA0
and Thanks  !!!     "Geo"
Acca...
