0 Members and 795 Guests are viewing this topic.
Void
Quote from: a.king21 on January 20, 2015, 06:01:02 PM
Just to throw in more controversy, I've just spent nearly 2 hours on video skype talking to this guy.
https://www.youtube.com/channel/UCk3RncET9rYzH6sTQafeR4g/videos?shelf_id=0&view=0&sort=dd
I'm still thinking about him. So no opinion yet.
Hi a.king21 . Not sure what exactly this guy is about since I don't speak Russian. Do you speak Russian?
All the best...
Void
Quote from: Jeg on January 18, 2015, 01:42:40 PM
Many thanks Void. This earth ground return is very tricky and also very misleading if ignored.
Yes, we are on the same truck. My inductor line running at 600khz is far more effective than katcher in producing radiant energy and filling caps. I am very curious in what will occur when tuned grenade will come in to play.
I am close to unity right now. With 48W input I take an almost full bright 42w bulb connected straight to grenade's end wires, without yet tuning grenade, or connecting an earth wire. The same time, while load is on, I charge a bank of some m.o. capacitors at 1.5KV just only from inductor side. I think it worth more testing on this approach.
Hi Jeg. How are your tests going with this? Sounds like you are getting better power transfer from the inverter to the load,
but not necessarily more than that. What is the capacitiance value of the capacitors you are charging? What's an m.o. capacitor?
All the best...
Void
Quote from: forest on January 17, 2015, 02:51:17 PM
If you return to the begining Tariel sent simple picture how it works. A current spike on top of slow wave low power. Just that.
Hi forest. Can you provide a bit further info about this Kapadnadze picture you are referring to?
Where did you come across this?
All the best...
NickZ
  The big 220v, 1000w bulbs may very important to the be able to pull in some extra amount of energy through the device. As compare to using the smaller bulbs, which most of us are still using. So, maybe at least use the 200 to 500 watt bulbs.
   Halogen bulbs have not been used on most of the shown self runners circuits, either.
  No Kapanadze/Ruslan/Akula self running device uses the small bulbs.
There may be a good reason for the use of only the big 220v bulbs.
   I'm still looking for some 220v bulbs to use, but haven't found any in my area, yet.
forest
Quote from: Void on January 21, 2015, 10:01:08 AM
All the best...
I can't find it. I reacreated it from memory. I hope I didn't forgot.
