0 Members and 127 Guests are viewing this topic.
Dog-One
Quote from: lost_bro on April 22, 2015, 10:45:42 AM
I like the fact that his designs have a simple, straight forward layout ..... ground planes included.
Without proper board layout and design, these circuits will *not* perform according to plan.  No breadboard monsters here....
So let me toss this out there for some feedback.  Thinking of ground and current flow, I made a modification to the snippet I posted above, where each MOSFET has its own diode, cap and resistor.  Not fully understanding how this works in a push-pull arrangement, I'd like to get your feedback prior to full-on testing.
The reason I did this is to keep the two MOSFETs and their associated drivers separated all the way back to the input ground plain.  When only having the one cap and one resistor, you're forced to tie these together someplace and from what I can see, there is no good "one place" to do this, without creating a ground loop.
T-1000
The entire setup is underunity until you get effect and this what also Ruslan said..
I was hinting several times about high frequency source from Tesla discharge circuit and how it affects transformers but nobody even bothered to replicate effect and see for themselves. Oh well, the ignorance is a business as usual for most people.
Also in several Ruslan videos when live scope shots are shown in tuning the dying oscillations are chopped off to the spike and this is what was used in first videos with nano pulse generator. This is what is creating radiant effect and most likely is making electrons pumping effect to the ground (remember Tesla spark interrupters?)..
P.S. Bat1, I did not solder these circuits and so not know each element function there in detail but the similar things was done in past and still are in youtube with Caduceus coil + D. Smith secondary on stivep1 channel when we did Lithuanian experiment back on 2011...
Also it takes long hard labor until you start seeing what to look for in self runner research and most of people are not so stubborn and do not have such patience.. Good luck!
Cheers!
forest
Bat1Robin2
nick,
Your wrong not one single video of a working device outside of the boxes, only open boxes of not running then video with closed boxes running if you have a link then post it. I have searched and watched nearly every single night even sundays for 2 months for videos there are no open box videos. Looped and running with no battery.
by the way the input generator signals can be driven from an arduino at 25khz if you want but the arduino is a little unstable on maintaining a study frequency.
Also if you increase the tesla frequency drive far above the yoke drive frequency,26khz up to 5 mhz  it does not help overall efficiency. but will light CFL bulbs better.
NickZ
  quote from T-1000:
"The entire setup is underunity until you get effect and this what also Ruslan said"..
I was hinting several times about high frequency source from Tesla discharge circuit and how it affects transformers but nobody even bothered to replicate effect and see for themselves. Oh well, the ignorance is a business as usual for most."
        end quote.
  How about you show us how it works, now, and not by bringing up the old videos, where you're using two signal generators
running off of the grid.  150w output, or 1000 watts, which was it?  No one can replicate it, including yourself.
  I do agree with you and Ruslan, that you won't see anything special, until the frequencies are matched properly.
Until then,  Earth ground lines won't help much, and the feed back circuit won't be enough to initialize self running, etz...
  The guy who is actually making all the shown Ruslan circuits driver boards, didn't learn to do that is a day, or a year.
  Edit: Bat1: If you are convinced that it's all just a fake, well, so be it.
  As T-1000 also mentioned, it takes a lot of patience, dedication, and tuning to be able to see the effect.
And, it's possible that none of the devices are what most would call over-unity, (more out than in), as overunity is a misnomer, and does not exist, it never has, never will. But, that some extra energy can be obtained by a circuit or system, that taps the available  and surrounding ambient energies, as mentioned by Tesla, is possible.
  Here in this video made just 3 days ago, Ruslan is showing his open boxes, and circuits running.  The effect at minute 1:50, or so, when he places the Kacher driver fuse into the socket. The resulting brightness increase in the single incandescent bulb, is the effect that we need to replicate. As well as when he is showing the additional brightness when also connecting up to the ground wire. This only happens at resonance, and there are different peaks that can be tuned to, which will result in varying degrees of gain at the output. The trick is in tuning to the best one.
                                               https://www.youtube.com/watch?v=XPL7bq5fs4w
