Kapanadze Cousin - DALLY FREE ENERGY
Started by 27Bubba, September 18, 2012, 02:17:22 PM
0 Members and 203 Guests are viewing this topic.
AlienGrey
Quote from: bitbo on February 06, 2017, 11:39:04 AM
Hi apecore !
Are you able and willing to share the corresponding circuit ?
Thanks in advance
bitbo
PS: I also had a "grenade measurement weekend" with some results on winding ratio behaviors
(not yet written down completely to share)
An interesting statement and request. However if you connect inject a signal generator to the secondary winding of your Grenade coil what are the pass frequency's  your device will allow onto the multi layer primary ??
Regards AG
T-1000
Quote from: AlienGrey on February 07, 2017, 07:43:22 AM
Regards AG
Hi,
The current focus on my side is to actually make Tesla coil charge environment. Then calculate grenade coil to that exact condition to receive signal.
As you know already, the reaching of sync effect and parametric LC resonances do not convert ambient energy.
  In my theory, the make of the current are magnetic field and electric field which are always following electric current. So assembling these fields on proper relationship should induce current on the wire. Which basically is the amplification of the energy in the system. The magnetic current is given on grenade from inductor and the electric current and static charges from the environment which the Tesla coil is conditioning. Still lots of experiments to do on that side but it may lead to ambient energy conversion results which could exceed power on the output than required battery power on the input. The time will tell how much truth is in that... :)
Cheers!
NickZ
  T-1000:
   Sounds like your spark gap idea that you got from Akula has not produced a self runner.
There is a reason that no one is using that method now. Which can cause the bulbs to flicker, also.
T-1000
Quote from: NickZ on February 07, 2017, 08:45:07 AM
  T-1000:
The spark gap is not being used. The electronic circuit with Tesla interrupter is instead.
But the whole idea is also in akula spark gap circuit for more easy reading.
Cheers!
apecore
Quote from: T-1000 on February 07, 2017, 09:15:00 AM
Cheers!
T1000,
That is right.....but maybe we jave to consider that a spark gap generates a complete frequenty spectrum.
Would this spectrum also be emitted by the antenna?
If so is the type of grenade in relation to fres(kacher/tesla) important?
Does that make the grenade design less critical
Cheers
Ps.  Bitbo....i need to confirm your request with MIB.
