Seven times more energy output than input: Power Multiplier Device
Started by Russell Lee, October 04, 2012, 03:20:25 PM
Low-Q
Quote from: webby1 on April 26, 2013, 10:11:52 AM
How many times is it necessary to remind you folks that in a mechanical device there are certain environmental constants that must be in place for the device to work, and how many times must you folks be reminded that in some systems at least one of those requirements can be replaced with gravity.
Yes. Replace the water column with one kg gravity on the lever to the left of the upper knob. Then replace the rod under the mainframe with some iron powder and look at it for 40 years. Maybe you start to see something moving.
What exactly did you mean with "replaced with gravity"? Isn't gravity everywhere in the first place?
Vidar
Low-Q
Quote from: ingyenenergiagep on April 25, 2013, 02:31:04 PM
"Input Time = 30s
Output Time = 3x60= 180s
Mass = 500lbs = 226.79kg
Distance = 10m
Work = M x G x D
= 226.79 x 9.8 x 10
= 22225.42 joules
Input Power= W x Ti
= 22225.42 x 30 (?)
= 666762.6 watts
Output Power = W x To
= 22225.42 x 180 (?)
= 4000575.6 watts
Excess Power = Po - Pi
= 4000575.6 - 666762.6
= 3,333,813 watts"
E= m x g xh
226.79kg x 9,81 x 10m=22248,099J
30s 741,6033W
180s 123,6W
Input power (Pi) = 22225 Joules / 30 seconds = 740 Watt / s (For 30 seconds that equals 22225 J of energy)
Output power (Po) = 22225 Joules / 180 seconds = 123 Watt / s (For 180 seconds that equals 22225 J of energy)
"Excess" power = Po - Pi = 22225 J - 22225 J = 0 Joule
Vidar
Russell Lee
Quote from: Russell Lee on October 04, 2012, 03:20:25 PM
www.squidoo.com/pinwheelgenerator   This generator produces at least seven times the energy than it needs to run.
                Thank you, Russell Lee
Again with one PMD at the top of the chain, and one located at every 30 second interval on a 3 minute descent/30 second ascent cycle, you have seven PMBS on the chain. This means when there is one ascending, there will always be six descending. Six full charges going into the battery, and one charge (without subtracting the energy being generated during the ascent) being drawn out.  Where is there a problem with seeing the excess energy being produced?
With 10/60, 100/600, one zillion/6 zillion.
Russell Lee
Tinsel,  on the last entry I meant to say that with seven independent PMDs, each spaced on it's own chain so that they are 30 seconds apart from eachother respectively, there would be six descending for every one ascending. The ascending one would be also charging an amount of energy back into the battery just by it's weight hanging on the chain.  As far as a prototype is concerned, I don't have one because at present I lack the resources to put seven PMDs together.  I hope to be able to some day. An unfortunate thing has happened in that the Squidoo site I had this information published on has fallen to corporate pressure and pulled my lens. Since it was out for over three years this is probable not serious for the design.  If it is authentic it will take off, if not, it won't, but with six PMDs charging into the battery, and only one drawing out, how could this not work? Russ
Quote from: TinselKoala on May 10, 2013, 12:58:35 PM
Where is your working prototype?
