0 Members and 43 Guests are viewing this topic.
forest
Yes, hanon. ;)  Precisely I think Figuera used already available dynamo machine and modified it to get slight space between armature coils and rotor, then rewound rotor to become strong electromagnet of the same strength as armature coils and placed rotating drum -output coils between them exactly in the center. The essence is good positioning.
stupify12
There you have it. Finally others are now starting to understand this invention. There is two of this Generators which is exactly the same with Nikola Tesla's generator. Either the Excitator Electromagnets or the Induced Close Circuit Coil is rotating which are both the same.
But I preferred the Nikola Tesla High Frequency Generator to be design like this. That machine is a beast on its own design, together with this robust  evolution.
Hope that you get soon to understand the Principle behind the Stationary Excitator Electromagnets and Induced Close Circuits Generating Coils. All are still the same following the Law of Induction which was discovered by Faraday. It is so simple that you should think like a box. Hehehehe. I think the patent from Stanley Meyer help alot in understanding this matter.
By the way. This invention was clearly described by Nikola Tesla on his modification of the Homopolar Generator on one of his books. It is cleary drawn in diagram  while Tesla describe how does it operate.
Meow..
hanon
Hi all,
This same principle is also used into Hogan and Jakovlewich overunity generator  (see this link to the Hogan & Jakovlewich patent ). This generator also used TWO OPPOSITE MAGNETS sandwiching the induced wire to create induction.
It clear that some atipical behaviour happens when the induction is forced to occur between two opposite magnetic poles.
A press reporter who witnessed Figuera´s device in 1902 said that "the invention consited of a motor, a generator and a kind of governor or regulator. The whole system being so simple that a child could work it."
    - A motor --> to move the induced wire . Just a small motor , because the wire didn´t suffered from dragging
    - A generator --> a device as described in Figuera patent 30376
    - A governor --> maybe to regulate the motor speed, or to feedback the motor with part of the produced current
Please see in this link the thread of Hogan and Jakovlewich generator:
www.overunity.com/14755/hogan-and-jakovlewich-overunity-generator/
Doug1
An Axial flux core-less gen does have drag on the windings caused by the output to load bmf. No overunity there.Your model does not include the effects of the field created in the induced coil by the loads attached to it.
  "When all ells fails try following the directions" I read that on a base ball cap somewhere.
Neo-X
@Hanon
I think its much better if the capacitor is placed at the primary of the transformer. If the primary of the transformer is tuned to resonance, this would produce 90 degree out of phase voltage in the output of the transformer.
