0 Members and 50 Guests are viewing this topic.
Doug1
Look a little more at the resister contraption. Why would he make two parts?one that rotates and one with all those connections to a resister cascade type thing? Is it a three dimensional object using two views in two D or is there really two parts?
sm0ky2
Quote from: Doug1 on March 21, 2015, 07:37:42 PM
It looks to me like a variable resistor (think radio), with multiplicative values of::
0 , 2, 4, 6, 8, 10, 12, and 13 respectively.
RandyFL
Isn't it the way they used to describe resistors...
All I know is the commercial electromagnet receives pulses of energy...and when I change the 6 100 ohm resistors to 2 ohms 25 watt there will be much stronger pulses...
All the Best
Randy
Doug1
Quote from: RandyFL on March 21, 2015, 10:14:02 PM
All the Best
Randy
Yes, but why are you guessing what size resister you need? Break down the Hysteresis curve into time increments for the core your using. Work only in the bread and butter part of the curve where change is greatest. It's not nice to hoard the world supply of resisters.
RandyFL
well at this point I can't figure why I'm getting DC voltage instead of AC...and the DC voltage is miniscule on a DC analog meter in the DC meter range of .25...
There's no instruction manuals on this approach...I was going along blindly to the video by woopy  " Generador Fiquera Approach 1 " on youtube. I used the circuit diagram on Kelly's website and got nice pulses in the primaries but hardly anything in the secondary s... Reading further into Wonju's posts He stated using 14 and 18 AWG and 300 to 400 windings He also stated that the resistors are going to get very hot as that's why Figuera used wire... So I am " assuming " smaller ohms and higher wattage lets in more power from the BDX53 s which in turn leads to stronger pulses in the primary s which in turn creates a greater magnet field which in turn leads to a voltage that could possible be around 20 volts with 5 amps in just one transformer........................
To clarify... I have the circuit ( with the 555 the gate and the 4017s ) and agree with Patrick that the semiconductor approach was/is superior to what Fiquera designed... but... and its a big butt for me is to show that the secondary in the transformers produces more energy than the primary s are using......I have to see it ( I'm from Missouri )...
All the Best
Randy
