NRamaswami
Doug1:
I agree with you but not able understand how the Magnetic amplifiers must be done. . Yes..I'm trying to lower the input to as much as 100 to 200 watts hopefully without affecting the output. Let us wait and see.
RandyFL
Induction by motion.
Yes. But instead of moving the inducers cores you may just move the magnetic lines of force and keep the cores static.
Quote from: Fernandez on July 04, 2015, 09:54:06 PM
This would be a good discussion.
- Fernandez
Isn't that the function of the Figuera ... " motion... Less " induction ( not being sarcastic or flippant here ). My point is this... electrical ( silicon ) steel in laminations reduces the eddy currents...
http://www.electronics-tutorials.ws/electromagnetism/electromagnetic-induction.html
" Eddy current and hysteresis losses can not be eliminated completely, but they can be greatly reduced. Instead of having a solid iron core as the magnetic core material of the transformer or coil, the magnetic path is "laminated".
hence... the figuera overcomes this by starting, then splitting and then stopping ( static ) as I understand it...
Lastly I think we should observe statements from Hanon, Bajac and others...
By: giving the location of the quote we use, or the location of the information that we use... or Bajac's stating... that He has stated something 3 or 4 times about the same thing...
We...minimize the confusion, mis quotes or redundancy... Not to mention the bickering, sarcasm... and who knows what else.
Cheers
Doug1
NRamaswami
  I will attempt to attach a pdf for you to bone up on mag amps. This one is pretty good even if it is old.
RandyFL
Quote from: Doug1 on July 06, 2015, 10:25:53 AM
NRamaswami
Doug1,
That's an informative pdf...
Cheers
PS responding to your comment
" If this is the work done in the 1800's you need to step up your game "
1. As I understand it... Clemente had the device built in three locations... if you were one of the builders wouldn't you be a little be curious at what you were building ( I would have built ( the part ) a copy of it in my garage - and my game would have started ahead of time )...
2. Main stream " science " has kept these devices or information from the books
3. Haven't you stepped up " your " game too... :-) ( just an observation...not a condemnation )
Doug1
 True ,you would have all sorts of time to contemplate as well.
  Here is another useful file. I know no one believes me. You will eventually reach conclusions by the process of elimination. If you can not explain to yourself what is going on in a device in a way that you can understand it then chances are slim to none you will be able to replicate it. There is very little chance of replacing parts with modern counterparts when you have no idea what the component requirements are. Which might explain all the smoke and melt of modern tech.
