marathonman
 I am sure glad someone FINALLY understands me.
Sounds good Mr Forest.
forest
I see  how magnetic flux is passing through the pair of identical but oppositely wound induced coils generating two equal and opposite counter-forces which negate Lenz effect , am I right ?[/size]
I have only two problems with this design. First Figuera rotating device with induced coils rotating alone and stationary cores
become very difficult to build if the original dynamo was that one you posted.
The induced coils must be on the hollow frame with spokes and the round core must be reall levitating inside this frame ! (imagine empty space inside the car tire)
It could be there is another arrangement of coils with the same properties but with other orientation of induced coils !
The other not resolved problem is how the commutator is made with not breaking the circuit.
Hopefully we ended that silly resistors topic , guys ? Do you see what I mean ?
marathonman
Hello every one.
I do not know if their was Mag Amps in Figueras days but it could of been easily implemented using the drum he so chose.
i to will not use resistors as this waste power through heat "BADLY" so i chose to use mag amps. by using two mag amps connected in reverse ie.... one high side/Low side to Low side/high side. in this fashion it will act "EXACTLY" as Figueras drum commutator did except no waste heat or parts to wear out. it can be controlled by Patrick's design/ or mine as i prefer,  to mimic the drum's action.
i know i have posted the mag amps in simplified form but the real one i am using in pictured below.
easily implemented using a small three phase transformer. and yes i can use a Toroid is so desired.
the pic below will have multiple dc taps to mimic the drum action increasing or decreasing saturation in the core causing the output to increase or decrease.
Forest/Everybody please study the actions of the rotating Dynamo more closely and you will see that #1 i am right #2 it will be easily to implement. all the rotating Dynamo does is reverse the flux through the core/coil every step of rotation. each advancement of the rotor shifts the flux in the opposite direction. then by daisy chaining them together "each pair acting as a battery" will raise the voltage to what ever is your desired voltage is. you can then parallel them to get higher amperage if needed.
Acoms razor: The simplest solution tends to be the correct one.  it was right in front of our faces all this time. so simple a child could operate it. we as human's tend to over complicate thing when the simplest solution was staring us square in the face.
FIGUERAS was a simplified Genius !
marathonman
IT can't get ANY simpler than this. pic #1 Red is high. pic #2 Blue is high.
the arrow in between cores/coils are just to show the direction of current.... in reality their is "NO" interaction between coils....no LENZ EFFECT.
hanon
Whoever that is doing tests should test every possible configuration and placement. Maybe this proposal is right , but we should not forget that NRamaswani has posted some experimental value showing OU results, and his cores were aligned. His post is to take into deep consideration. He seems to have been testing in deep and try many configurations. I see just one flaw. He should redo the measurement with an oscilloscope to assure that the output is or not greater that the input, or do any kind of calorimetry to measure find the number of watts out.
Also we have to take into consideration some of the Buforn´s patents. His patents show that the cores orientations. If his patents are not right we should then consider that he is lying to hide the true configuration and his patents were not valid in that case. I attach here a zoom of one figure from one Buforn´s patent
