0 Members and 25 Guests are viewing this topic.
hanon
Note that Gennady Markov transformers have North-North orientation in the primaries. I do not see your 90° angle in this transformer.
If you read my post on the 11th of may you will note that something weird , not explained by current science, happens where the magnetic field is null. Floyd Sweet,  Gennady Markov, William J. Hooper, Gennady Nikolaev, ...etc
marathonman
Hanon; I just brought up Genady just to prove a point to antijon that Lenz is what is killing Transformers not aiding.
i am quite aware of the different winding method but in this case of Figueras i don't think any of those method's are used in his devices.
he took a rotating Dynamo and made it stationary.... no bells, no whistles, no fairy dust just logic plain and simple. he even states that it is unbelievably simple and couldn't believe someone didn't think of it.
yes i know B fields cancel E fields add i read it but don't agree with it in Figueras devise.
it desn't matter if you see 90 degree in it or not because the transformer is split to negate lenz any ways.
antijon
ah haha...
Marathonman, thanks, never heard of Markov, however, I'm very knowledgeable with his
work. His device is a dual-primary transformer, which I've already mentioned here... as I have
independently researched. Eventually I'll start a new thread about it. But that has little to do
with efficiency. And it also has little to do with balancing magnetic fields, which he states. It's
simply that multiple primaries multiplies the EMF.
Lenz law in a transformer... if you guys don't know, I'll be happy to explain it.
marathonman
Doug1 had ask me why did they abandon the ring dynamo.... well all the ring dynamo's of Figueras time were limited to 15KW output. isn't that just a slight coincident that figueras device put out 15KW.  these Dynamos were of Figueras TIME.
another coincident is ALL of them had the inducers flux at 90 degrees to the coil length, NOT one but ALL of them. so why do you think i have my coils arranged the way i do....BECAUSE THAT'S THE WAY IT'S IS SUPPOSE TO BE.
Figueras made it stationary to eliminate drag, separated the cores to eliminate Lenz effect and WIRED it the same way....."WHY" because it worked the first time. "FLUX CUTTING ALL DAY LONG"
yall can argue all you want, add all kinds of stupid crap n fairy dust to over complicate it but in the end all you will have is a NON WORKING DEVICE.
marathonman
Finally found the missing 3-D parts for my board design. looks much better with all the parts on it.
found them on the MFG web site and had to do a lot of adjustments but it was worth it.
also added power LED to the board.
