pedroxime
Marathonman you are right on the money ;)
The only way Figuera could do it work at that times is following the principle "KEEP IT SIMPLE STUPID"
Toroidal generators were well known through 19th century and much more eficient than current ones
He only evolued them to static.
Listen carefully to the beggining of this video when he speak about the toroid: "19th invention and internal cancelation of back EMF"
Its it , I made test and it works
https://www.youtube.com/watch?v=Zu4pzvkSkzo
Doug1
Marathonman
  Sorry it will be a a while before I can retrieve the paper I wanted to post with the math so you can determine for yourself what quality and quantity of power you have to account for in your method. Much as I complain about technology being so easily broken I failed to move some files to safer place. I would actually rather use books made of paper but they are too costly to acquire and maintain.
  The reason they moved both magnetic poles to the inside of the ring was for economic and safety reasons. The same principles are still used in automotive alternators which have evolved to operate under the conditions encountered in a vehicle engine compartment as the principles of the old model you have in the pic. There are as many differences as similarities in actual design but I am referring to principles of induction.
   Even Faraday's disk does not follow Faraday's own math since there is no cutting of the field by the normal rules of induction used in all the other types of generators. In spite of that it did not stop people from making disk dynamos some of which were massive multi ton units. They are hardly practical to operate for 99.999 percent of the population. If you address how the unit in question was able to run itself with out a prime mover or any additional input from the source the possible finish designs are limited only by the imagination of the builder. The only important thing is how he closed the loop. How you conserve the magnetic field while it is in motion while taking from it the effect of induction into an independent circuit to do useful work. I could tell you how to make a perfect loaf of bread but if I did not know altitude has an effect and you were at a different altitude then me then you would not be able to make that perfect loaf of bread.You would claim the recipe does not work. I have nothing against trying to get lucky if you only wish to make your own for your own personal use never to be replicated ever. After all why would I care how much time or money it cost you when it was for your own satisfaction. I wouldn't. There is an old saying measure three times cut once.
marathonman
pedroxime this is truly a joyous day. i knew i was right all along i was just waiting for yall to catch up. HA HA HA ! and thanks for verifying it before i could get a chance to.
Doug1  i will very much appreciate the formula. as soon as you find it post it.
Figueras is SMILING from ear to ear. young Padawan you have done well.
THANK YOU MASTER !
MagnaProp
Quote from: pedroxime on October 21, 2015, 07:07:46 AM
Saw the video but didn't notice the part where he explains how Lenz is not there.
You put two coils in series on a toroid and it magically has no Lenz problems?
