0 Members and 97 Guests are viewing this topic.
bajac
Schiko,
I have not finished the H bridge or my set up yet. It will take much longer than what I had expected to build my unit. I am hoping that a member from the forum could complete it soon.
I wanted to ask if someone knows of any dynamo or small motor/generator that can output two AC voltages shifted 90 degrees. If we can get such a unit, it would be very easy to do the input driver. We can use a small VFD driver to control the speed of motor driving the dynamo. For the 1908 device, if you want the output to be 60Hz, the input voltages should be 30Hz.
Bajac
ariovaldo
I put a video showing the electromechanic oscillator operating. To say the true, I did't like it. The brush is the one that is rotating and doing that, the centrifugal forces is holding the brush without touching the commutator, so wave form is more a square than sine as should be.
Solutions for this system
1) increase the spring size
2) modify the the commutator/brush holder, so the commutator will turn
Others solutions:
1) solid state device ( hanon/Shiko)
2) use pure ac 60 HZ
3) modify a small generator and use as VFD to drive it. ( I do have a VFD and I will check generator)
The most important part is the transformer and I do know that. My intentions is modify the transformer in video, creating a small gap...
The transformer connections are based in the Grumage drawings
Cheers
http://www.youtube.com/watch?feature=player_detailpage&v=nAeWdqSCTek
ariovaldo
Quote from: ariovaldo on September 26, 2013, 03:38:28 PM
Others solutions:
Cheers
Something very interesting happened !
As you can see in the movie, the light seems to be half way bright and the voltage that I used was 80 VDC.
As I said, the commutator was not OK, and it wasn't generating sine wave. Was a kind of pulse/square.
After the test, I disconnect the system and I connected 110 AC, at the same point, keeping the the 2 out-side coils in serie as was, and I had nothing in the output. I got some ideas for the next test
hanon
Quote from: hanon on September 25, 2013, 02:28:11 PM
Time ago I saw another patent of a MEG based on air gaps but I can not find it again. If I get to find it I will post it here also. Carlos Subieta Garron literally writes in his patent US3368141: "The assembly will not work as an annular magnet, there should be a small air gap between the core member and the shoe poles" (please note the attached drawing with the air gap !!). Air gaps are used to "re-route" the magnetic field to avoid opposing the inducer coils, thus minimizing the Lenz effect over those coils.
I have been looking for that patent that I saw time ago with an air gap to achieve overunity in MEG. I have found some references. It seems that the "air gap" has a clear function to get a minimization of the Lenz Effect over the inducer coils. Just for the record these are the overunity references to air gaps in transformers:
http://www.overunity.com/4300/a-truly-overunity-transformer-meg/#.UkSESVN5DC0
http://www.overunity.com/11256/curious-ou-transformer-schnelzer-turtur-horvath-marinov-any-replications/#.UkSFc1N5DC0
http://pureenergysystems.com/academy/papers/9600214_Energy_Anomaly_in_Magnetic_Circuits/
http://www.overunity.com/7833/thane-heins-bi-toroid-transformer/msg248924/#msg248924
Flynn patent US6246561: http://www.google.com/patents/US6246561 (see figures 1 to 16)
We should give a greater importance to the air gaps as elements to minimize the Lenz Effect by redirecting the induced magnetic flux along others paths different than the inducer coil.
Schiko
Quote from: ariovaldo on September 26, 2013, 05:09:04 PM
@Ariovaldo
Not wanting to disturb your fun but perhaps it was better to use a set collector / brush motor.
Your commutator seems to create great spark, I think there is too much space between contacts, remember Mr. Figuera said...
"a las delgas incrustadas en un cilindro de materia aislante que no se mueve; pero alrededor de él y siempre en contacto con más de una delga gira una escobilla"
Just above of this text he said...
"Para fijar las ideas es conveniente valerse de la figura adjunta que no es más
que un dibujado para entender el funcionamiento de la máquina que se
construya según el principio antes reseñado"
I understood that meant that drawing is just to understand the principle of the machine not to interpret literally.
Use collector as photo 1.
Use resitores all equal and measure with oscilloscope by using a resistive load at the output of the commutador and you have a waveform with this photo 2, the output of Transforming you will measure a sennoide almost perfect.
I know, I know you're having fun!!!  ;)             (uma imagem vale mais que mil palavras)
cheers!!!
