0 Members and 153 Guests are viewing this topic.
Doug1
Norm and Marathonman
  An insulted conductor does not limit you to copper. I replaced 6 diodes in my small portable welder which is a 220 volt wire feed and was marveling over the two transformers and all the beautiful shiny wire only to realize it had not one stitch of copper in that machine. It was all aluminum wound and varnished to look like copper. The only difference was that for each 5 layers there was air space with spacers to provide better cooling of the windings.It has a forced air fan that runs when it is connected to a power supply. There is guy on youtube who made a pretty beefy magnet for demos.He is a teacher and does demonstrations for his students on the power that a home made magnet can have. He used aluminum foil to wind his magnet and easily lifts 400 lbs plus runs a 12 volt wench to raise and lower the magnet when attached to a bar that can hold weights or people that all runs from a 12 volt car battery. Im not saying you need such a big magnet just that a conductor is a conductor and what it is made of is less the point of conducting if the price is such that it is more affordable then swap to different material. I keep 5 welders on hand because I abuse them and the wire is never what goes wrong, it's the rest of the parts like diodes and control boards and fan motors. That welder carries 12 diodes in all and they are far from easy or cheap and that is not even that big of a welder just used for small work short and quick. Not a big fan of diodes. Maybe you can find some al wire and re-purpose it if copper is hard to get.
norman6538
I did some better tests with the stack of magnets in a wood block to hold them well.
see attached photo for the setup.
results are.
wood cylinder setup... and stack of 3 magnets and 4th after 1/8 wood gap
the magnet stack is placed on top so you can see how it is made. It goes
into the hole and is held there by an aluminum plate.
1. R = 1.5 inches pushes car
2. A = 5/8 pushes car when the "breaker coil pm" is flipped to repel the stack
  which simulates the Kunnel "breaker coil" flux change.
3. S = 1 inch  -single mag attracts car
so you can see that Kunnel even weakens the single magnet repel...
I corrected some incorrect words above.
Norman
hanon
Norman,
KunelĀ“s patent just uses one inducer  field while Figuera uses two opposing inducer fields NN. Kunel is based on flux linking induction, as transformers (no magnetic lines cut the induced wires) , while Figuera uses the second field to collide against the first field and move the fields to create induction by flux cutting the wires, as in generators.
If Kunel says that his device works, then, or the device just produces a few watts (useless in real applications) , or I can not understand how he is not still a multimillionare after more than 30 years.
marathonman
So what you are saying Doug that one could use copper or aluminum foil to wrap primary or secondary coils. that would give the most bang for the buck. i checked on ebay and copper foil is not all that expensive. one 9.8 lb spool of 18 awg cost me 68.00. at 9 layer filler the same with foil would be around 6.5 to 7 feet.
it would seem worth while to do a core with it to find out.
thanks for the info.
RandyFL
The car alternator is the answer until the Figueras is solved ( as MarathonM pointed out )...
If the pulley was larger it would naturally go faster ( more juice ) as Doug1 had stated it does run itself...
Left alone the diodes ( and they are sturdy enough ) they could power anything in the DC area... if taken out the alt. is 3 phase AC ...which incidentally the alt. could be refigured into a 3 phase motor with the b emf used to control it...
I'm not saying stop the Figueras research...I'm saying use the Alt. until its figured out...or invest in the LEDs and alternator company :-)
Lastly...
Ignacio ... please finish the translation ( the bottom part ) of post #3206
R
