norman6538
I cobbled together Hanon's posted circuit from a few pages back and tested it
on a test bed I had setup for Flynn, Figuera, and Kunnel tests and got 53v out of
the secondary coil with 120v input. Since the coils are all in the same direction
I had to flip wires to make the poles alike in the center. When they are unlike there
is a solinoid vibration that can be felt and heard. The coils are 900 ohms from the
water in valves in a washing machine. In the back right is a 4th coil that is the resistance that reduces the power in one coil by half - 1800 ohms. And the diodes
are there too. I drew the circuit on the plywood too. That reduced current did
not change the output much....that surprised me. The core is a bolt
and the  C clamps are used to hold it in place for rapid prototype changes.
Prior to this my std AC test gave me 43v so Figuera is 23% improvement but nothing
like we want to see.
Do I need to do current tests to nail this down?
Thanks Hanon for showing that circuit. It is so easy to use.
The earlier Kunnel PM tests showed that the PM had little effect on the voltage.
It does not enhance or deter the voltage much. So my conclusion is that
the electric flux out powers the PM flux.  Maybe you have some thoughts
on that.
So why do we think we can get these old patents to work after all these years?
Better luck fellow experimenters.
Norman
marathonman
Sounds like every one is beating there head against a rock with this circuit. the whole reason Figuera did what he did is because when two electromagnets is taken up and down in an orderly fashion a duel e field is created and maintained. when it is pulsed in the circuit you are using it is not plain and simple.
cuss me out all you want but in the long run who is right.
Sir; do you think your ohm's might be just a tad bit high.
norman6538
Marathonman
What is a "duel e field"? one in each coil?
Norman
forest
Two pulses at 180 degress are fine but how to get two at 90 degrees ?
