marathonman
I was using it as an example as to the extent of magnetic's has on the control of currant. you do know what reluctance is don't you.
what your trying to do i don't know or care but you are hampering the forward movement of this forum.
instead why don't you prove me wrong (in which you can't)
the Figuera device part G uses magnetic field to control amperage but i guess that is to far over your head or out of your range of intelligence to prove me wrong just post some stupid pic .
Figuera device part G is a continuously rotating Rheostat or varidc if you will with a continuously rotating field inside the core. as the brush rotates so does the field.
but i'm sure everyone is dying to know your Figuera device operation ...... so lets see it seeweed i mean seaad.
MM
ignacio
Si, te dedicas a contestar suposiciones, terminaras desviándote, de tu idea, sigue derecho, y no hagas caso a las menciones.
If you dedicate yourself to answer assumptions, you end up straying from your idea, go straight, and do not listen to the entries.
seaad
--> MM
"" i'm sure everyone is dying to know your Figuera device operation""  They already know from one of my previous posts
     seeweed  ;D
cliff33
Hj all:
  I'm having a hard time understanding why all you people are building a commutator that uses high wattage
power-wasting resistors, when the job can be done with only a few electronic components.
   Basically we only need 2 mosfets and and an op-amp to drive them.
The mosfets need to be a complementary pair. An N channel and a P channel, so that when a positive
voltage is on the up-swing, the N ch. current rises and  the P ch. current decreases. Of course just
the opposite happens on a down-swing.
  These fets require  no power to drive them and a cheap common op-amp like the 741 will do the job.
Mosfets are readily available in different voltage and current ratings. They can be easily paralleled to accommodate
whatever the current required.
The op-amp would be built as a sine wave oscillator to drive these things with an off-set
voltage to ensure that the sine wave never goes in the negative direction. Frequency can be changed at will.
So let's get going!
