wistiti
hanon
Hi wistiti,
I think it is a good revision because now it collects the polarity in repulsion North-North, and I think this is an essential part of the device.
I miss the 1908 patent text which was already incluided in the previous version. Also I miss a reference to a current regulator composed by resistors, that it is the one explained in the patent claims. Resistor are easier to understand for newcomers than the magnetic reluctance rheostat, which maybe is an optimization but it is more difficult to understand at first sight. For me the essential key is to swing back and forth the two magnetic fields. The method to do it (resistors, rheostat, capacitor, magnetic amplifier,...) is secondary. There are many possible implementation to get the same result.
norman6538
Hanon I made the circuit you refered to below but did not get the same wave forms on
a scope. I got the DC humps up but not down....Did you have any success with
this circuit?  Did anybody else make the circuit??? any results??
Norman
Hanon said abour march 10 or so...
Yesterday I was testing the circuit posted by Ignacio on the 26th of february to use half wave in each inducer by rectifying AC with two diodes, post #3185 http://overunity.com/12794/re-inventing-the-wheel-part1-clemente_figuera-the-infinite-energy-machine/msg475611/#msg475611 and frankly the shape of each of the two signals is quite good. Minimun current of 0.2 A and maximum current about 2A with 12 volt AC input. I used a resistor joining both diodes outlet in order to assure a minimun current,as base current, during all time.
I attach the pic with one signal. The other signal you may guess it unphased 180°. I post to show it because it is an easy way to implement the input signals. Maybe other people could also use it. Really simple.
Still testing this new driving circuit. So far no important results to share. Output was small but a very good AC shape at 50 Hz.
wistiti
Quote from: hanon on April 02, 2016, 07:39:21 PM
Hi wistiti,
Thank you for the reply!
Yep again the same concept "bucking feild" as Chris Emjunky try to tell to everyone...
Thank again! You do a great job!
wistiti
Quote from: wistiti on April 02, 2016, 07:09:43 PM
Hi hanon what do you think of the last update of the pjkbook?
http://www.free-energy-info.co.uk/Chapter3.pdf
Look at page 24...
I wonder if it is better to have a core for each coil with a small gap betwin the coil or one unique core for the set of 3 coils...???  Have you a input on this?
