0 Members and 162 Guests are viewing this topic.
darediamond
Quote from: cliff33 on April 12, 2016, 02:26:09 PM
Darediamond,
"How will the lenzless HIGH FREQUENCY AC OUTPUT from the Center Secondaries be tapped and used if HIGH FREQUENCY Diodes are not first employed to rectify that aforementioned output and then converted back to AC by Simply using an inverter?
Can you explain Mr?"
From your question, I can only assume that you believe that diodes have to be added to the output of the secondary.
Well yes ,but only if you want to drive a 12 volt inverter for 115volt 60hz output.
   I also assume that you believe you can't run a load directly off the ac secondary coil. Not true.
I'll be driving my primaries at much higher frequencies than CF ever could.
I can use my ham rig to light up a 100 watt incandescent bulb using 4 mhz.
You can run any resistive load directly from the "y" output.
"You can run any resistive load directly from the "y" output."
Unless connected in series, the Secondary output voltage will always be lower while amperage will be Higher if Thick AWG Wire like AWG#14 or 15 or 16 is used to wind them. So few HOUSEHOLD Resistive devices runs at low Voltage.
So to go universal powering all form of devices it is far better to turn the output of the Secondaries to DC using FAST SWITCHING RECTIFIER DIODES and link that output to an Inverter.
You can even make a Lenzless  Spiral Wound Primary Coils Center Tapped Transformer For your Inverter Driver.
It can be done.
Think outside the Box
RandyFL
Don't just talk about it... do it! And take a video of it running without a power source ( or disconnected from it ).
cliff33
Secondary voltage is dependent on turns ratio and voltage ratio follows suit.
e.g: If primary has 100 turns and secondary has 500. that's a ratio of 5 to 1.
If primary is being pulsed at 10 volts then secondary voltage will be 5x10 = 50 volts.
Why would you want to prematurely change the  pulsed output to pure dc before testing for over-unity?
I could find many ways of loading that 50 volt output, just for testing.
We should all remember that Tesla's later years were exclusively devoted to experiments
in pulsed dc. Maybe it's just the pulsed dc that attracts the free energy. Nobody knows for sure.
We have to walk before we can run. Just one step at a time.
seaad
Eagles soar, high above all, seeing everything..   even the truth
nul-points
Nice investigation, seaad!  Would it be too much work to replace the 'rotary' coils with Figuera's 'resistors' in your LTSpice sim above and compare efficiency?   tack så mycket!  :-)
