0 Members and 110 Guests are viewing this topic.
cliff33
Darediamond:
But why go that slow and costly lane when you HAVE A FAR MORE BETTER OPTION IN THE NAME OF INVERTER??
WHY??
http://www.circuitsgallery.com/2012/09/sg3524-pwm-inverter-circuit2.html"
This chip only puts out 60hz for a regular dc to ac power inverter and you still need the power amplifiers.
An 8 pin op-amp or even a 555 chip can be made to put out a sine wave at any frequency you want.
It's a far easier solution for experimenters than a complex 16 pin ic that has features we don't need.
   I agree with you that higher frequencies would greatly increase efficiency. This was proven years ago when
they stopped using bulky power xformers in computer power supplies & instead are pulsing very small xformers
in the khz range. Ultra light units that can put out 20 amps.
Don Smith said that doubling the frequency would quadruple the output.
     I don't think HV is necessary for this unit to work. We only need a strong magnetic field that keeps varying in
the one direction. It can be made as strong as you like just by reducing circuit resistance.
    Because magnetism & electricity are so closely related, you can use either one to attract free energy.
High voltage potential of a single polarity is one way. Or a strong magnetic field that varies only in the one direction
is the other.
    Too bad people get confused between the two and want to use both at same time.
Here I will state my theory along with the dozen of others on this thread.
   Charged particles of matter (only pos. or only neg.) are attracted into the strong magnetic field of the air gaps.
Therefore the more air-gaps or units the more energy we get. This is also why CF used 7 units.  Magnetic exposure
to the environment, I think is the key. This being so, then the width of the air-gaps might need to be optimized.
   CF was trying to replicate the theory of a dc dynamo which has a half dozen or so coils whirring past a magnetic
field coil. The more coils, the more power.
   That's the main reason for his 7 units. Other reasons are:
1. A coil too large in diameter will suffer inefficiency.  Outer layers not getting as much magnetic field as the inner.
2. Not enough room for larger coils.
3. Coils with large circumference will need much longer wires for same amount of turns.
darediamond
Quote from: cliff33 on April 29, 2016, 03:33:09 PM
Darediamond:
WHY??
is the other.
I strongly agree with what you said here ''I don't think HV is necessary for this unit to work.'' because we can now easily switch the Primaries without using Mechanical Switch.
The benefit of using variable frequency inverter lies in it type of Voltage which is far beneficial as regards cancellation of BACK E.M.F Generation and the option of Voltage Application adjustment. All-in-one you will say.
When you use mechanical means to switch a coil, that will attracts B.E.M.F which will need H.V Film Capacitors to quench using the correct capacitance. I knew this from Practical test. In other words, if you do not absorb those sparks with the Non-polarised  H.V Film Cap, the resulting spark will kill the Commutator and render it useless as a Mech.Switch. DC is mostly associated with Mechanical Switching and low end IC to Mosfet Switching and as for using IC and Mosfet, that B.E.M.F is a pain in the butt too because the spark will be occurring inside the Mosfet which can render it permanently useless in a jiffy.
So the best option is to make a Varible Frequency Pure Sine Wave inverter. As this allows you to switch at low Voltage and use Transformer to amplify such low voltage to higher Voltage if necessary.
That IC will output 60hz if you use Fixed Resistor on it Pin 6. But if you use variable Resistor, you will be able to arrive at more high frequency.
That is cumbersome when compared to AC application which does not pave way for B.E.M.F and far suitable with powering Figuera prototypes because it posses Iron Core.
darediamond
Quote from: marathonman on April 28, 2016, 09:29:52 PM
It's amazing, people that DON'T even Know what PART G is are suddenly an EXPERT on Figuera with no working device giving out advice on how to build a free energy device.
NOW THAT'S PRECIOUS.
Hanon can i interest you in two SHAM WOW'S and some rubber spoons for the invaluable Tech support you just received.
you should be thrilled.
The heart pulses in a vortech motion. meaning it twist's as it contracts, if you want to sound like you know anything at least research it first.
It amazes me how you wrongly assume I know nothing in Practical about the disadvantages of your proposed mechanical switch which I nullified based on my Research.
What tech support do you have to offer?
Teach us something we do not know Mr. Marathon.....
What happen to your device?
hanon
All,
Are you sure that you want to follow a felow as the one that send  messages as the copied below. Just for your information.
I just say: read the patents, study them, and later test every possible polarity. But follow the patents !!!
marathonman
Building Part G the way figuera Built it as we speak, by the way lets hear your interpretation of part G that you so called nullified. oh my god what a good laugh.  EVERY ONE can be at ease now that  darediamond has nullified part G.
you offer nothing just like Rswami does, just a lot of hot air that NO BODY follows that has any common sense.
My final device is almost complete how about yours, and i did say "FINAL".
Hanon i wouldn't follow the nut case if you paid me to. i think i'll stay my path."the right one"
and by the way Hanon didn't bow, he came to his senses, because i sent him all of my research plus he has his own and he quit listening to stupid shit.
imagine that !
