0 Members and 91 Guests are viewing this topic.
hanon
Doug,
I have been studying the Tesla patent No. 382282 that you referred previously and I cannot see the similarity with the system with like poles facing each other. Where is the idea in common in both designs?
Doug1
forest
Doug1
Arc was a type o , ac connection.
  examine the generator closer KK K'K' the gen has two field magnets it;s simple ac generator so why the four slip rings and brushes? Trace out the connections to the annular ring.
  What will be the hard part is to get the fields centered so that the exact place where they reside in the induced is evenly positioned amongst all the sets so when current is shifted between the inducers it happens at the same time with the same amount. A method to test the field strength of each inducer while in place needs to be established. Any difference of sets will counter the effect in the other sets.every electromagnet of the inducers has to be exactly the same in strength and volume. If you have more volume of iron core or wire in half it wont react evenly on that part of the cycle.
forest
Doug1
So you state there is something interesting with generator , hmm I was surpriced by two brush pairs but text explains that he took two ac waves each from separate coil of generator.There is no K and K` , only K.
What was very strange to me is the connection of load to the shunted coil ! Trace it please, Tesla even state it has more current into load. That is not series or parallel connection I'm aware of.
