marathonman
I was asked just the other day how in the world can the primaries exert motion into a secondary when both are stationary. ?
the primary electromagnets cause the E fields but it is the relative motion of the primaries being reduced and increased with the opposing secondary field between them that induces currant flow into the secondary and the load. once the polarization takes place and currant begins to flow the primaries and the secondaries part ways and it is the primaries becomes the motive force that exerts motion into the secondary provided the circuit is closed with resistance of it's own. ( ie a load)
So lets stop and think about that for a minute. the compression of the two opposing electromagnetic fields dictate the intensity of the electric field and as one is reduced and the other is increased both E fields are in the same direction as both are positive and additive.
now the only time power from the primaries (inducers) are transferred to the secondaries (induced) is when the secondaries are to be polarized. once this polarization takes place and currant begins to flow in the secondary and the load the Lenz law comes into play and an opposing field to the first is formed in the secondary.
since this opposing field will be in between the opposing field of the primaries it is the relative motion of the primaries being reduced and increased that pushes that opposing secondary field across the Electric field formed by the primaries in the space between the primaries occupied by the secondary. this will cause the secondaries to appear to have the illusion or appearance of motion in them to the Electric field thus currant will flow.
once this process takes place the primaries and the secondaries part ways and it is the relative motion of the primaries that exert motion into the secondaries provided the circuit is closed with resistance of it's own. after they part ways each system is essentially completely separate and no other time is power transferred to the secondary system. the power requirements of the induced (primaries)  is reduced to that of just the IR2 losses and the replacement of the currant in the process of reducing the primaries to get motion into the secondaries then back to full potential.
the power used to sweep the opposing secondary field ( Weightless Massless Field) across the Electric field formed by the primaries is so rediculously small that the unit can power it's self and the load once it is started.
part G in the patent is basically a dynamic inductor that increases or decreases the currant through the primaries that exert the illusion or appearance of motion into the secondaries.
BA-Bang said Figuera, someone actually listened to Mr Doug.
Marathonman
marathonman
A very good point that was posted another site talks about overunity laws.   http://www.overunitybuilder.com/index.html
Overunity law #2 that states Iron acts as a currant amplifier and that is so obvious that i don't think it needs to be touched upon except the 1932 Coutier device uses this concept exclusively as does all generators of any kind.
what i want to talk about is the OU law #3 that states electromagnetic energy can be recycled. to me this is a DUH ! statement since energy can not be destroyed only converted to another form of energy so to me it is quite obvious that it can be transformed from one energy state to another with ease. some are nonrecoverable as in the form of heat.
in an LC circuit we have the magnetic field potential from the inductor as it is being reduced transformed into an electric potential of the capacitor. when the capacitor releases the electric potential it is converted to the magnetic potential of the inductor on a continuous orderly basis.
In part G we have those energy states taking place. when part G which is an inductor it stores and releases magnetic field potential from the system on that same orderly basis to the form of electric potential. each half rotation of part G there is a rise or fall of the inductor potential either converting it to electric potential off setting the potential drop of the rising side of part G or storing the electric potential in the form of a magnetic potential in the rising side of part G.
The primary electromagnets do the same thing as part G. when the primary is rising it is storing a magnetic potential in it's field and the reducing primary electromagnet  field is releasing the magnetic potential into the system in the form of an electric potential. both released magnetic potentials of the reduced primary and the reducing part G inductor are converted to electric potential offsetting the potential drop of the rising electromagnet and part G as they are storing into the magnetic field.
what we have then is a very orderly rise and fall of potential that is constantly converted from a magnetic potential to an electric potential and back again many times a second depending on your country.
Part G becomes the power supply once the initial power supply is removed and it recycles the energy in the inducer side imparting motion into the induced side which is a closed system of it's own.
THIS ACTION CAN NOT BE DONE WITH A RESISTOR THAT WASTE ELECTRIC POTENTIAL AS HEAT. THE ELECTRIC POTENTIAL IS CONVERTED TO HEAT POTENTIAL THAT CAN NOT BE RECOVERED BY THE SYSTEM AND AMOUNTS TO MASSIVE UNRECOVERABLE LOSSES. ON THE OTHER HAND THE ELECTRIC POTENTIAL CAN BE CONVERTED TO A MAGNETIC FIELD AND BACK CONTINUOUSLY WITH VERY LITTLE LOSSES WHICH IS THE IR2 LOSSES.
Part G becomes the power supply once the initial supply is removed but as all systems build by man has inherent losses the secondary output is there to replace those losses occurred through heat, wire (IR2) and core losses.
Marathonman
NRamaswami
If resistor array is wasting Electric Potential why Prof. Figuera put a resistor array before the current went in to the Magnetic Cores? Why did he do that?
A resistor array makes a low voltage Electricity to high voltage Electricity. But it would reduce current. What is the secret behind application of high voltage to a magnetic field and what happens when voltage is boosted.
Questions Questions No answers
marathonman
I guess i spoke to soon about the trolls.
The Figuera part G is NOT A RESISTOR ARRAY of any kind, it's an positive brush ROTATING INDUCTOR.
NO resistor array in the world will make low voltage into high voltage. what planet are you on ?????
It is quite obvious that you do not have the intelligence high enough to understand what i have been posting and i do not have the time or inclination to try to to lower the technical aspects so you can understand this device..
I mean no disrespect at all sir but how many times do you have to read the patent that states. and i quote; " R the resistance is drawn in it's elementary manor to facilitate the understanding of the function of the device." end quote.
That means in plain English that what is shown is not the actual device. it is used to just explain the function and that is it. so what are you left with if it is NOT a resistor. think on that. (if possible)
I would surely suggest that you pick a device that you can actually understand it's functions as i really doubt anyone on this site has the time to explain it to you especially since it's been four or five years and you have learned absolutely nothing.
I see nothing has changed since years ago and it is quite obvious you learned absolutely nothing over the years.
stop asking stupid questions and see/understand the intelligent answers right in front of your face.
if you can't .... oh well to bad. some people just do not have what it takes to learn something new or outside the box and i believe you are one of them Sir.
REREAD post 4220, 4223 and 4230. if you still can understand don't come crying to me because i don't want to hear it.
Marathonman
marathonman
What really amazes me is the total non advancement  in the field of magnetic's and electricity in general in the last 118 years. it seams quite obvious in my research that JP Morgan was one of the sole perpetrators in destroying the advancement of these fields guided by good ole Rochefellers and the Rothschilds. he literally took school books from the system and had them changed to rid all traces of free energy. this would be grade schools and colleges and he spent millions in this process.
HOW SICK IS THAT, TOTAL GREED AT IT"S FINEST.
what also amazes me is the simple act of pulling a magnet or reducing an electromagnet from a coil causes the induced currant to reverse direction (reversed Electric field).  how in the world can something so disgustingly simple be so severely overlooked through out the scientific community is totally beyond me.
a simple technic of taking one electromagnet or magnet in or rise of currant and the opposite on the other side to reduce in currant or taken away from the coil causes the doubling of the voltage from the coil. what is amazing is Clemente Figuera did this 110 years ago and was purposely hidden from the people.
we can not sit by idle and let these rich disgusting fools take advantage of us any longer.
the Figuera device is simple, it uses a dynamic rotating inductor that varies the currant to two opposing north face electromagnets that cause the doubling of the electric field from the action of one electromagnet being reduced and the other increased all while keeping both in total unison. as long as the pressure between the primary electromagnets are maintained the Electric field presented to the secondary will remain at it's highest potential with increased output.
what is killing people is the standard way an inductor is used in present day. since people are so hypnotized by present day dogma science that states an inductor is just a passive device that just sits there and curbs currant only for a short time and stores then releases a magnetic field.
when on the other hand if you have a positive rotating brush on an inductor wound on a core with it core and winding's changing as the brush rotates causing both sides to increase or decrease in length will cause an orderly rise and fall of magnetic fields used to curtail currant on an absolutely orderly basis. then using those magnetic fields in a positive advantage manor to offset the potential drop of the rising side and splitting the feed into two separate feeds.
currant in an inductor will change in intensity if the condition of the circuit changes ie.... the amount of core material,  the winding count and the length of the inductor. even if the circuit is presented with say 10 amps the window of the inductor will allow only the amount you need as per the winding count and the radius of the brush.
this very use of an inductor takes it from a passive device to an active device on a dynamic basis as the brush rotates. and this my friends can not be found in NO school books around the world.
welcome to my world and the world of Clemente Figuera and the infinite energy machine.
AND THAT MY FRIENDS YOU CAN TAKE TO THE BANK, LOCK, STOCK AND BARREL.
Marathonman
