0 Members and 53 Guests are viewing this topic.
marathonman
So basically what part G does as the brush rotates is change the ratio of magnetic field to the amount of currant. as the brush rotates the amount of winding's change magnetically linking to the circuit increasing the magnetic field. since self inductance is the reverse EMF that opposes currant flow in the first place the more winding's we add the more opposition to the original currant flow we will have. the opposite is also true, the less winding's we have in the inductor the less the magnetic field the less opposition to currant flow. with a currant rise in the increasing side of part G's magnetic field it is gaining in intensity but the overall space occupied storing the increased potential is small with little reverse EMF.
the iron in the core will enhance the reverse EMF aiding the self inductance of the inductor. if it was an air core the currant reduction would not take place so the addition of the core thus amplifies self inductance to the point of  linear currant reduction. since the real currant flow is from negative to positive the currant flowing into part G from both set N and set S will cause an North><North opposing magnetic fields at the brush and it is these fields that keep the two side of the inductor separate at all times. so what we end up having is one huge inductor separated by magnetic fields divided into two at the brush each acting separate but in complete unison.
we have as the brush rotates  two inductors either increasing or decreasing in length,  increasing or decreasing the reverse EMF to the original currant flow that causes a complete orderly rise or fall of currant in a linear fashion. then to top that off as the currant is reduced the reduction in the field will release that reduce part into the system aided by the reducing primary's potential plus the secondary loop back causing an amplification of potential to the rising primary.
marathonman
Every single thing i have said has been verified on the bench. the person that put it in my mind was Doug in the first place in which i do thank you for the wonderful information.
the opposing magnet test can be performed by yourself at your own home that mimics the Figuera device. the self inductance to curtail currant can be performed at your own house. every single thing that has been presented so far can be verified BY YOU AT YOUR OWN HOME.
This device was real and IS REAL thus can be built by ANYONE.
This is a quote from Aubrey Scoons that replicated Royal Rife's work;
"DON'T BE FOOLED!
Complexity does not equal credibility. Just the opposite in fact. Anyone who has genuine insight will be able to explain to you in simple language exactly what they mean and you will then be able to verify it with known scientific fact. If they can't.....well, what do you think?"
This is why i choose to explain things in detail but at a level everyone can understand. it is usually the troll or the Ney Sayers that try to use words that you can't understand or even dishonest tactics to discredit/belittle you.
Marathonman
marathonman
Keep things adjustable when building the Figuera device.  since the primaries are exact copies of each other plus putting them on bobbins allows you to have adjustment done on the fly.
also on part G once it is wound will not be so adjustable so by using the adjustable post like below will allow you to adjust the balance of the primaries if needed. they are cheap as in a few dollars and save a hell of a lot of time.
taking the screw out and flipping the tab allows you to use it much better than the original way.
now it can be slid very easily, they can take fairly thick wire and a lot of amps to boot. this makes it easier to adjust since part G is one continuous wind.
Marathonman
marathonman
In the Figuera device he used DC to excite his primaries just like a standard generator does to excite it's N&S fields not ac that some people seam to think. if one was to use AC there would be all kinds of phasing issues to deal with and this is unacceptable and a royal pain in the backside. not only would that cause hysteresis and eddy currants in the primaries and this is detrimental to it's magnetic field output. since the time it takes to plow through the resistance of the wire and the flipping of the magnetic domains are far to long to respond in any reasonable manor. thus would be darn near useless in the FIguera device.
by using DC in his device it eliminated all hysteresis and eddy currants but also the phasing issue involved in using AC. the secondary has these effects that is why he split the cores up the way he did. using DC allowed him to get the highest possible magnetic field from his primaries without all the said draw backs. by using DC and winding them specifically as electromagnets he was able to attain the highest magnetic field possible with the fastest rise in magnetic strength.
since he used DC and did not reduce his primaries down below half way this technique allowed the primaries to be reduced and increased to full potential with very short response time keeping a very orderly rise and fall of the primaries to remain in complete unison throughout this action.
just think about that for a while with some common sense. if one was to try to use AC in their primaries,  the time it took to rip through the resistance and to flip all the magnetic domains which would never happen because before the all the domains got flipped the AC is traveling the other way so the resistance and the flipping of the domains starts all over again. so what you would end up with is a rather weak electromagnet that gets hot from eddy currants and hysteresis. the time involved to do this process is crazy slow and coherency between the Electric fields would be lost and induction would fall to that of just the rising electromagnet.
now with that common sense still flowing by using DC that never reverses the Electromagnets do not have to deal with eddy currants or any hysteresis ill effects nor any phasing issues to contend with. when the DC electromagnet is brought up to proper field strength and reduced to just clear the secondary then back to full potential the time frame of that action is so minute that the primary Electric fields are able to remain in complete coherency. thus induction is at it's maximum and the output is the square of the two primary electromagnets compared to two plain bucking fields (NON COHERENT). very little magnetic domains are flipped in this process once it is at full potential because all Figuera did was reduce the currant to just clear the secondary then back to full potential which does not flip the domains like AC would. the electromagnets remain cool and have very fast response time.
in the process of splitting the DC currant both primary electromagnets remain in phase at all times and are just reduced in relation to the secondary and not them selves. since the wall at the collision point of both opposing electromagnets will be quite large the reduction of currant to get the primaries the sweeping action across the secondary will be quite small. not to mention the opposing field of the secondary once currant starts to flow in the secondary and the load will be sandwiched in between those two primary electromagnet. refer to the squirrel cage motor action Doug referred and apply it to this scenario.
the primary electromagnets cause the E fields but it is the relative motion of the primaries being reduced and increased with the opposing secondary fields between them that induces currant flow into the secondary and the load. once the polarization takes place and currant begins to flow the primaries and the secondaries part ways and it is the primaries becomes the motive force that exerts motion into the secondary provided the circuit is closed with resistance of it's own. ( ie a load)
thus in compliance according to Faraday's laws of induction ANY rise or FALL of the magnetic field will cause induction no matter how small.
thanks for everything Doug, to bad nobody else listened to the wisdom brought to the table.
If you still cant understand what i have just laid out in plain English in a logical and descriptive manor i would suggest you chose another device or field to pursue because your failing at this one.
Marathonman
darediamond
Figuera  mainly avoids to use of magnets to creates alternating field. His version however is not fully motionless as he like Nicola Tesla DID NOT HAVE ADVANCED ELECTRONIC COMPONENTS IN HIS TIME AS WE HAVE IN OUR TIME NOW.
So Figuera device a means to convert D.C to Pulsing DC or better still AC which is exactly what Mechanic Alternators produces as the magnets on the rotor is arranged North-South-North South and on and on like that.
The opposite winding  is meant to negate Lenz but you Can aslo {Like I have done} practically negate Lenz with RESONANCE and thus use little copper wire. High frequency application plus resonance will allow anyone to use little materials to generate kilowatts of Power.
Yes the output at low voltage high current will be in high frequency which will then needs High Frequency diodes to rectify and further needs Inverter circuit.
Make it simple brothers and sisters as YOUNG only needs to understand the Figuera Gen basic fundamental working principles for you to know what to add and subtract in view of new era available Electronic components.
Why will I keep to tidious mechanical lane when more Super easy, efficient and effective motionless Route is available!e?
May God bless Donald Lee Smith!!!!
