0 Members and 159 Guests are viewing this topic.
marathonman
ramst; Lets not go there, your better than that.
Again i rest my case.
Blindly posting erroneous thought as if they were even tested on the bench let alone backed by Physics and science. that post is exactly my point i have stated for many year that Rswami post total BS that has not been proven on the bench nor has he EVER built any device other than the blunder of a transformer he calls the Figuers device that is a transformer not a generator.
He blindly post his twisted thoughts as if he was an accomplished scientist and builder which is a total scam job perpetrated by him to fool people into thinking he is one in which he is not. when has ANYONE actually seen a single picture of his work toward the Figuers device other than the hideously  monstrous device that is a transformer yet struts around like he is the Authority on the Figuers device. i literally laugh in your face.
If any person believes a single word that comes out of his pathological lying mouth is a complete fool and should have his head examined by a shrink.
I post real Physical proof about the Figuera device that has been verified on the bench not some Psycotic ramblings from a pathological liar and you should be barred from this web site for being a complete fraud.
RSWAMI IS A COMPLETE FRAUD.
Marathonman
NRamaswami
Mr. Marathonman
Please post pictures of your bench device and videos. Thanks for at least recognising I did some work and the device you consider to be transformer and not any thing else. At the least I put up pictures and gave measured readings.
Where is yours?
d3x0r
Quote from: NRamaswami on May 03, 2018, 11:21:43 AM
The primary coils can be easily arranged to make first core to be made up of thickest wire, second somewhat lesser in thickness and so on when a minimum amount of current would flow through the last core. We can put the same type of coils in the reverse order in the other primaries to make the same effect so that the secondary would be exposed to different current on either side always.
You do not need a part G to be present today. We need to oscillate the direct current from a battery for this arrangement to work and this is where the Part G  was used in Figueras times but today with Transistors it is a much easier task and Part G is not required. We would only need to use a 555 transistor to be able to oscillate the DC current going through a Mosfet.
This arrangement will obviate the need for a resistor array and Part G as shown in drawings. But the variation of current must be present.
Was alternatively going to propose multi-tap battery/capacitor cells switched for varying current; but that led to lots of work done by the ends and much less in the middle; which would be hard to overcome too...
Quote from: NRamaswami on May 03, 2018, 11:21:43 AMI suspect that it is a permanent magnet core and the primaries are Air core. An iron core offers resistance to current and so would draw lesser current than an air core.  Even if there is no iron in the primaries the coils in the air core would make the induction to be present in the secondary permanent magnet core in the center and they have to oscillate the permanent magnet in the center only.  This would enable the gap to be present whether we use the identical pole arrangement or opposite pole arrangement.
If the permanent magnet core is present in the center irrespective of whether the poles used are opposite poles or identical poles the oscillation of the magnetic field would be present. When the coils on the secondary are subjected to time varying magnetic field they must get induced electricity. In my experience higher the voltage of the primary higher is the voltage of the secondary. Greater the number of turns of the secondary higher is the voltage. Higher the voltage of the secondary and greater the magnetic field strength higher is the amperage of secondary.  These are practical hands on observations.
Hans Coler device?  Coils wrapped on permanent magnets, I guess in theory mutually interfering with each other to cause generation... https://rimstar.org/sdenergy/coler/index.htm
@MM
(yes the following mentioned circuits have nothing to do with Figuera; before you decide to chase that bone)
a mazilla/royer circuit has an inductor to serve exactly that function; I would see that sort of current-drive inductor as needed to be common ( before whatever causes a current variation between N and S ) because any one of the target coils is going to either need to be restricted in flow or boosted in flow as its current changes.
The kacher drive used by akula/ruslan had a similar inductor on the common input; before any of the active parts of the circuit.
If a thing is > 1 COP I'm sure it can be > (1+loss through resistances) by a significant amount.
A coiled coil is more significantly the magnetic field of the smallest winding direction.  If you were able to make a very long, thin coil, and then coil that coil into a coil; the apparent current motion is greatly reduced, and any inductive amount of the resulting coil made from a coil as its filament is barely relevant.  so why wouldn't it just be a straight coil with muitiple taps? that's certainly easier to draw; instead of being drawn as a heater core?  And don't the words associated with the image also specify?
Anyhow this pdf summarizes both of your views.
http://www.free-energy-info.com/Figuera.pdf (555, and the uhh variac thing)
http://www.rexresearch.com/figuera/figuera.htm
*shrug* I don't even see anything that says G and not R.
I did just see a educational video about quantum physics and waves... and water has been shown to interfere wave-like through 2 slits... but the motion of the wave isn't the particle itself, but a measureable result of a particle moving.  Consider that under the water is something more viscous and denser than water... call it molassas;  so the LHC slaming particles together at energy level X, can cause lots of ripples in the water, but don't distrub the underlaying molassas layer very much; but with higher energy; or constructive interferance of two other events, you can cause ripples to form in the molassas layer that you can see that sort of result happen... and that things in the universe are like this, but have many many layers like that that...  (probably need better/more words to actually convey that)
https://youtu.be/-4Mz4OGVC_U?t=42m7s  (42:07 is near the start of that with some groundwork that leads up to the nessecity of the analogy)
The other thing someone said is that higher entropy is lower energy; so heating something is working in favor of the 2nd law of thermodynamics; although heat does sponteneously move to cold, which is working against entropy.
And then of course; in a universal coordinate system ohms = per-seconds.  Or what was that other thing Eric Dollard said?  Voltage only happens because of resistance?  Because of current being stopped?
marathonman
Yes, i see the intelligence level dropping like mad and wonder when the actual common sense will kick in. can someone page me when that happens.
and i quote; "To fix ideas is convenient to refer to the attached drawing which is no more than a sketch to understand the operation of the machine built using the principle outlined before"
and
" Let be "R" a resistance that is drawn in an elementary manner to facilitate the comprehension of the entire system"
I rest my case.
and how will you negate the potential drop of the rising primaries since in your so called version does not have a part G. i would also like to see the device running by it's self. yep that's what i thought, there is no device built of that nature because it can't and won't. so that paragraph is purely theoretical and has never been proven thus a figment of your imagination .
NN orientation has been proven by me with Science and Physics and can not be disputed by you or any other bobble head on this site.
bobble heads begat bobble heads.
so i guess the real information on the figuera device is over and now it is time for fantasy time and fairy tails. sorry i only deal with Physics and real truth.
maybe someday you Rswami will actually get your hands dirty and do actual research and testing on the bench that proves everything i have stated unlike your psycho babble you call research. and why do i need to show you anything as all you are going to do is run down to the patent office to try to get a patent. sorry you just don't have the intelligence to understand this device let alone build it.
I hope everyone has a good day and don't let that head bobble to much. neck injuries are not fun.
Marathonman
citfta
Quote from: marathonman on May 03, 2018, 11:04:04 AM
it would seem after five year people would would pull their heads out of their backside but i guess reality just came crashing down as it seems i have been talking to bobble heads with the information bouncing off of the heads like that of a pinball machine.
Marathonman
So for  5 years you have been telling everyone how to do it but you still don't have a unit that works.  It appears the person full of horse manure is you.
By the way INDUCTORS DO NOT store a charge.  You have them mixed up with CAPACITORS.  Maybe it is YOU that should be applying REAL science instead of your BS theories.
