0 Members and 35 Guests are viewing this topic.
marathonman
(If you have tight (thick) wires running parallel both on top "plate" and bottom "plate" from end to end.)  (I'm always making tests before I put out my nose )
(this is NOT tested at all!)
Quite obvious and typical of you. sorry won't happen as the magnetic fields are opposing. open your darn mind and see the magnetic fields are opposing. it is like talking to Hanon or a brick wall with you some times and very aggravating knowing i am right and you are wrong. why can't you see the magnetic fields are opposing is beyond me and i really can't see justifying our conversation any longer as your intelligence is lacking in this area and is total BS as always.
Me, i tested everything i post on the bench.
good day and good luck as you will definitely need it.
Regards,
Marathonman
seaad
Quote:
" The problem with this comes with all the crossings in the middle not the electrical part, if you have tight (thick) wires running paralell both on top "plate" and bottom "plate" from end to end.
To solve that make two levels of crossing lines. (this is NOT tested at all!) " It's obvious I can't test this because I don't have the MM  flat C core.
I have tested the "cross winding principle" there are no opposing fields at all on the contrary.
A
marathonman
I realized  after studying your wiring directions that is was a misrepresentation that is why it threw me off. this is the corrected one and showing the magnetic field directions. connections will be on opposite side of each other. red on both sides is impossible when winding like that.
it is still a waste of a lot of wire but yes it will work and possibly use a smaller core..
Regards,
Marathonman
seaad
MM Quote:
" it is still a waste of  a lot of wire but yes it will work and possibly use a smaller core."
A lot is not so much! The inside diagonal part of the winding A-B is slightly longer, Yes, than A-C for each turn compared with your original "one plate" winding.
But to get 4 x Henry if you wish that you need two times more turns. To have room for them on one "plate" you need to shrink the wire diameter!
The benefit with my suggestion is that the wire size still can be Thick by splitting the tuns.
The negative electrical behavior maybe is that the bruch only touches every second  turn. And is much harder to wind on two C-cores.
Regards Arne
marathonman
  The winding pattern just seems to be a waste to me but hey it's your thing not mine.
received my epoxy today in the mail. it is 3,300 PSI sheer strength epoxy with a three hour window tack time with 24 hour cure. should hold the winding's quite nicely in place.
Here is the link....  https://www.monarkgolf.com/golf-components/tools-supplies/24-hour-shafting-epoxy-total-8-oz..html
Regards,
Marathonman
