0 Members and 31 Guests are viewing this topic.
dieter
Thanks. Reading all 50 pages did in fact establish your nickname  :) . Please let me know when I obviously miss something.
One interesting thing, that contradicts the books, is, when I applied a voltage to the pancake coil, then monitored the field, it did not cumulate the strength radially as expected, but gave a stronger field just away from the big cake surface, kind of like a loudspeaker. The thin side at the other hand didn't even draw a line.  Such things teach me not to trust the theories too much.
Thanks for your suggestions. I didn't think of a smaller core for Y.
An other thing I think I have seen is: tbe magnetic fields of a permanent and an electric magnet did not accumulate like 2 permanent magnets, but it seemed they were more like overlayed. Could that really be? Could it be that they are not the same kind? Ok, just a strange observation that I really need to verify.
The ratio of the number of turns will also determine the voltage in the secondary. Additionally I  have made the observation that a rather little number of turns is better for a strong magnetfield that can build and collapse quickly, where for the secondary a higher number of turns will help to achieve a voltage at all, at the cost of lower amperage of course.
The problem with the gaps is: using as little gaps as possible is just the same like using no gaps, but then take a material that suppresses eddy currents (eg. a core made of welding rods, or painted spokes or painted iron wire), or maybe a core that is conducting the magnetism but not any electricity, like ferrite. Too bad I only got two "E" cores made of ferrite, and not one straight one. Will do some more tests later on.
marathonman
We as human  and the science community actually know very little to nothing about this universe we live in. only a few actually know the real workings of it and they are massively censored and controlled. what little information we have are used to attempt in building of free energy devises that that may or may not work as almost all patients are mangled to the point that the information is hard to follow. so that leads us to follow are hearts and mind of reasoning and interpretation  threw the collection of information. in that note i would suggest collecting all information about Figueras and other related devices and through self experiments, i.e. trial and error to "GET THIS DAMN THING RUNNING" with the help of your friends of course.
i would start by trying to follow Figueras to the tee for starters. his set up is like a transformer except he is splitting the primary in two to avoid the nasty Lenz law  that simply related to two like charges. these two primaries have to be bigger than the secondary because of the losses from material i.e. winding , core and gap losses. in this process of primary separation we have two opposite charges that attract one another and the reaction of the air gap mitigate the Lenz actions that allow the secondary to produce uninhibited voltage and currents that steps the voltage down and raises the amperage.  we then series them for the desired voltage like a flash light battery and use it in any form we want...i.e AC/DC one for house the other to power are cars for ever. allowing us to STICK IT TO THE MAN SIDEWAYS ! oppression is real and active and we are the "Gardians of the gate of Humanity" and have to stick together.
NRamaswami
Hi Marathonman:
What you are saying about patents being deceptively worded is ok. It is correct to a point.
You are confusing between Lenz law and Lorentz Force Law. Please check wikipedia to know the difference.
This is neither a step down transformer nor a step up transformer. When you talk about transformers you talk about stepping up the voltage or stepping down the voltage. This is a Generator that uses transformer emf.
Let me explain.
Induction motors work on the principle of rotating magnetic field. Induction generators work on the principle that if the rotation of the core of the induction motor is increased to an RPM higher than the RPM of the rotating magnetic field, the increased rotation would convert the induction motor to function as an induction geneator. RPM is nothing but frequency.
In a Transformer the rotating magnetic field is the casue for the electricity being produced in the secondary. So theoretically speaking if we manage to increase the frequency of the output in the secondary, then the transformer should be able to function like the generator in the same way the induction motor has been made to become an induction generator.
Is it such an impossible task for more than 125 years to be achieved? I'm not an electrical engineer and all of you know that I'm a dummy in Electrical engineering but all of you also know that I'm a hard working and straight person. Let us see if any one can say this or that circuit can change the frequency of the secondary of the transformer.. Then that transformer will become a generator. Not a transformer that steps up or step down voltage. This is what Figuera did. So this is why it remains a mystery device.
Let me know if the above principle is wrongly stated for I have not studied physics and most of you know that I'm a dummy. So if I make mistakes I have no problem and I will correct myself and learn..
marathonman
Yes i know i was referring to one Law  but spit out another (sorry). no i was talking about the patient office deceptive practices and patient being reworded or pages/info missing. as to the induction motor/ Generator, there has has been accounts in early Germany that some people have rewound a motor to act as a generator at the same time so YES it is possible but i myself haven't the clue how to do it.  i think the word you or should be using is Ignorant not Dummy. the definition of ignorant is "NOT KNOWING" the other...well you just can't fix stupid in which you are NOT. every person will have a different interpretation of the same thing that is why we are here to hear other people's interpretation and together come to a logical conclusion. i had an epiphany earlier and this is what i came up with. this is the wave form of Figueras devise or rather my interpretation of his/my wave form. THIS IS VERY SIGNIFICANT TO FIGUERAS SO PLEASE STUDY and please advise.
Quote from Doug1 ----The point where the two fields meet will have a shear line separating them like two window fans blowing at each other.The air will circulate around the fan like discrete bubbles circling each fan. The center point of collision of the air has two opposite direction of flow. If your hand is more close to one fan it feels the air flow and direction from that fan and if closer to other it feels the opposite. If the fans are alternately slowed down and sped up the collision/wall will move side to side". N/S-S/N exactly what is taking place below in my Paint pic. zero line is moved side to side of normal zero.
dieter
Remember it was said by witnesses, that it was unbelievable that such a simple system was not invented already earlier.
After some tests with cores, the ferrite core has 1500% effiency compared to a simple iron core. So now I' m doing some coils for it. Running out of wire here  :'( thinking about to sacrify a microwave oven supply... desperately searching for alternatives...
The pulses are indeed important, nice drawing BTW. As I see it, characteristics are as follows: while in Primary A the pulse is crossing the zero volt line, Primary B is already at 50% voltage, this means Y  will never rest but always being pulled in one direction, where the change of direction must be very fast, compated to the entire pulsewidth.
