New Perm Mag Engine Design 1.5 : 1 Ratio (work from magnets)
Started by Floor, August 05, 2013, 08:36:48 AM
conradelektro
Quote from: Floor on August 12, 2013, 02:01:25 PM
@conradelektro
After reading that thread, I then Looked at the archive of your postings here at OU.  I give you an over all grade of A, for integrity.  I hope I can do as well here.
Greeting  floor
@Floor:
It is easy to do better than I am doing in these threads, because I get angry when reading embellishments and boasts. And I wish I could do more experiments. It is easy to talk/write and so very hard to build something decent.
I have a tendency to rant about sharing and patents. But I am a bit proud that I found and tested some Joule Thief type circuits and pulse motor circuits which I could replicate successfully. (I did nothing new. I understood, replicated and measured.)
Your magnet machine is the first "permanent magnet contraption" that caught my interest, because you are measuring instead of claiming. And I realy would like to analyse your "curves" once you have done the measurements. Do not try too many measuremenst, because you could loose interest. I think that about fife to seven measurements per set are enough. For the "pure friction set 3A and set 4A" three to five measurements are enough.
The measurements do not have to be evenly spaced along the track. Put more and more water into the container and note how far the sledge moved or the rotation proceeded. You can note the angles from your scales. One can calculate "distance" from "angle".
A measurement set would consist of five to seven pairs of numbers: angle (or distance in mm) - millilitre. I just need these "pairs of numbers" and will do the diagrams with a drawing program (TurboCad) and the calculations with a spread-sheet (MS-Excel).
Greetings, Conrad
Floor
@ conradelektro
I am taking the day, to get some recreation and exercise. i will do the next measurement sets later in the week.
Cheers
        floor
conradelektro
Quote from: Floor on August 13, 2013, 11:32:22 AM
Cheers
        floor
Floor, are you sill planing to do some measurements?
Greetings, Conrad
Floor
@conradelektro
yes.
I'm still looking forward to doing measurements.  Some money making projects, and another magnet related project have kept me busy.
I may begin measurements to marrow.
Floor
No measurements yet!
I'm still doing prep.  Here is a progress report.  My printer is out of ink so,  right now,  I am at the local library printing out a chart to write down measurements upon.
I may finish by this evening ?
                                                 Cheers
                                                           floor
