Bashar's Spacecraft Engine
Started by teratologist, November 20, 2013, 04:21:16 PM
Hope
Glad you included that photo of the disk and crystal.  "As one wire"  I want to ask you if each wire passing thru the crystal should be made to be connected to 1/4 of the spiral ends?
(off topic a bit but for information:  when a Rodin coil is made the wire does not even have to have a shellac coating to keep from shorting out)  Is your wire coated or bare?
BTY shellac is made of insect shell.
Having seen and repaired so very many circuits over the years, I ask myself what steers the charges and I can not understand how or what separates them.  In the end all I could think was that Bashar left out some "of course" items....."Of Course" means common circuit components.  Until we figure out what is missing we will trial and error through a slow learning process.  Steering germanium diodes?  Separation of the copper rod by the crystal?  IDK  but you have made the most difficult parts already and they look accomplished.
Recently I have read that animals know natural disasters are coming due to magnetic abnormalities.
[Supposition: (If magnetics attract the electrons as it passes the wire in a coil, and there is an opposite but equal reaction happening.  What does it repel,  protons?  Just possibility.  Then the repulsed flow of protons is cold electricity and does not flow restricted like electrons. This I can only venture to think and not know,  but atoms somehow keep moving.  I see things in this world move that are out of balance seeking to become balanced.)
The original action is a movement against a natural balance and has resistance.  The proton flow is the natural countering balance action and therefore is like the fall of a coil voltage.  It proceeds unimpeded (without resistance). ]
I believe that when a coil is grounded the only back emf is caused by the opposite flow (protons) having to make room for the new movement (returning the electrons), therefore it becomes resistive slightly due to the natural constant pressure caused by all matter in this pool we call the cosmos.
edited for clarity (I hope)
WTF
All the wires are bare copper, no coating.
I've tried connecting the copper wires at different lengths, even to the same length of the full diameter, I've even soldered the wires to the net. When I take the crystal out I always check to see if all the wires are still connecting to the rod, I check this before and after every time.
I still think that the problem could be that the wires should be curved inside the crystal as to follow the Fibonacci spiral, as I'm sure the crystal plays a critical role, but unfortunately I can't cut the crystal in half as the diamond blades that fit a Dremel are to small and I'm not going to buy a saw just on a wild guess, I've tried to see if anyone local could cut the crystal in half but no luck, as carving the wire grooves would be easy.
Assuming Bashar isn't a figment of Darryl's imagination and is real, you could be right that components were left out, after all he is a first contact specialist, which does not make him an engineer, so maybe he doesn't understand his own technology, especially if he's old, as old people aren't normally very good with technology, there's lots of people on our planet that don't understand our own technology.
WTF
Thought drilling more holes in the crystal might work, but it doesn't.
Hope
Your talented WFT,  hope what ever your doing in the job market is something you can express these talents.
WTF
