Bashar's Spacecraft Engine
Started by teratologist, November 20, 2013, 04:21:16 PM
WTF
Quote from: gauschor on January 21, 2014, 09:32:18 AM
Thanks for this thorough explanation. Now I agree that in this context the word "penetrate" shall be understood as something that "goes through physically". Also makes sense in all cases when Bashar uses this wording.
Do you also think the wire net should make contact at every crossover point?
WTF
Could I have other peoples options on the wire net contacting the rod and if the wires on the net should be in contact at every cross point. Thanks
WTF
Just tried drilling the amethyst with a coated diamond drill bit 3mm, but being coated the diamond bits come off in a few seconds, even had a faint orange glow where I was drilling, I've search for a bonded diamond drill bit, but they seem to start at 5mm. sometimes they are called brazed or welded, if anyone knows where to get one preferably in the UK please let me know.
The reason not to do the hole to big is when you drill quartz you drill through both sides to stop the crystal breaking from the other side, even with the rod through it, some breakage will happen, so the bigger the drill bit the more the crystal will break, if it breaks to much then the 6mm hole the rod goes through won't be a proper hole anymore, which can't be good.
I'm also thinking if the wire is really meant to go through the crystal, I'm sure its meant to touch the sides, otherwise why go through the crystal and not over the top, so drilling a 5mm hole, the 0.56mm wire won't touch the side to much, and the more crystal that is removed the less power would be available.
gauschor
Quote from: WTF on January 21, 2014, 09:36:06 AM
I am not so sure about that point unfortunately :-| Or if the whole wires shall be insulated or not. Although it would make sense if they were not insulated as you said - so it can touch the crystal. But what's the point of all these non-insulated wires if they all are connected to each other. It's like all of them being on the same niveau/potential. Or is this on purpose? Hmmm... let's hear some other opinions.
WTF
Even though there not insulated, doesn't mean they have to touch, but if they have to touch why not just in the centre, why every contact point?
At the moment I have one person's opinion, with the wire net touching the rod and the wires of the wire net making contact with each other, that's why I want other people to state their opinion on this, especially with the wire net, takes a long time to make it so I need to be like 95% sure before doing this, or at least if lots of other people think the same as uniquorn then maybe there's something in it.
I wished I lived in LA, I would go to one of Bashar's shows and ask him.
