GEM = God's Electricity Multiplier
Started by that_prophet, February 06, 2014, 09:19:10 PM
0 Members and 18 Guests are viewing this topic.
that_prophet
free energy is done using pulleys
http://free-energy.yolasite.com/
It uses the simplicity of it not taking 100 times as much force turning a 100cm circumference pulley, as it does turning a 1cm circumference pulley, yet you get 100 times more LENGTH OF MOVING BELT to work with. If you run the 100cm of belt by any # of 1cm circumference pulleys, you would gain the # of mini-pulleys times the multiple of 100 units of AC electricity.
THAT IS WHY I CALL THIS AN AC ELECTRICITY MULTIPLIER
that_prophet
HERE IS A LITTLE OF WHAT DRIVES ME,,, TO ENDURE YOUR HARASSING COMMENTS
Atomic structure proves that there must be a God. How else could All things, including dirt, be made of atoms. Atomic structure is so supremely complex, that man, with his superior brain power still cannot explain how it was formed, + we know that it could never have been formed in any explosion, like in the big bang theory.
Most all humanity feels that spiritual lives are not reality + this solid world around us is reality. This life that we call reality, we now know is only a simulation, practically nothing of substance, all air + minute particles,(which we keep finding is made of smaller parts) + massive energy=atomic structure. (energy that is in extremely complex settings)=settings that we humans are still trying to figure out = (where they came from, how they were formed in the first place, what they are made of, what is their purpose, how long will they last)
ALL OF WHICH POINTS TO A SUPER INTELLIGENT CREATOR
ALL SCIENTISTS VIEW GOD'S HANDIWORK DAY IN + OUT
Everything we see + touch, is made up of varying layers of complex organization = life, organic tissues, inorganic materials, chemicals, atomic structures
If EVil_sOLUTION were truth, then why is there only about 6000 years worth of space dust on our moon=God's Creation hour glass. What happened to the billions of years worth of space dust, which would have been many meters of dust, instead of the mere millimeters that we see on the moon landings.(if you take the amount that falls to the moon every year, and divide it into the amount that is there, you get closer to 6000 years worth, than billions of years=these amounts are known-just look them up) Why is it that all mutation are cancerous, and none are beneficial.
ALL MANKIND,,, YOU HAVE LESS THAN 3 YEARS
TO BECOME BORN AGAIN + ESCAPE,,,
OR GO THROUGH THE 3.5 YEARS OF FAKE PEACE
+ 3.5 YEARS OF GOD'S WRATH
WHERE GOD SENDS SATAN + ALL OF HIS FALLEN ANGELS TO OUR EARTH
THEN HE SEND 7 SEALS + 7 TRUMPETS + 7 VIALS OF JUDGEMENTS ON THIS EARTH
http://beliefstoliveby.yolasite.com/
that_prophet
The full explanation of GEM=(God's Electricity Machine)
I truly do not understand the mass misunderstanding here, can't you see that evil forces are at work, keeping you from believing this Gracious Gift of God's. This was easily understood by everybody that I told this to, and they agreed that it was so obvious, that it just had to work. I will try to explain it in the same way, that I explained it to them.
            I started off by telling them that I had a large 100cm circumference pulley, and that it was connected to a DC motor. Then I told them that it only took one single spark of DC current, to rotate that large 100cm circumference pulley one full time. This would give you 100cm of moving belt, which you could then run past 1 to 10 mini-pulleys of 1cm circumference. This would give you an output of 100 to 1000 units of AC electricity, which you would run through some full wave bridge rectifiers,(4 diodes): one for each AC generator that you are using. This way you would get a lot more DC current than you would need to power your DC motor for one rotation.
           Now, try and tell me that you could not get the one spark of DC current, that you needed for your input drive motor, out of the 1000 units of AC electricity that you get as an output. Thus, you have a set of AC+DC motors/generators that run continuously, that you should be able to tap power off of, and the greater the # of mini-pulleys with AC generators attached, they greater the amount of current you should be able to coax out of you leads off of your full wave bridge rectifiers.
This was given to me for the Tribulation Saints, (I ask my ABBA Father)
+ I don't think that they will have money to buy all of these items.
When this is meant to be super simple + easy to build out of odd spare parts.
All that you need is a DC motor + an AC generator of the same voltage.
One large wheel/pulley, (like a bicycle rim) + at least one mini-pulley/wheel, (a thread role)
And a few full wave bridge rectifiers = (only 4 diodes each)
The hard part is when you would have to rig up a way to connect your motor + generators to your pulleys, (glue or threading of some sort,,, you cannot weld or bronze them, unless you found a way to disassemble them or heat sinks, to keep from frying your winding's)
Myself, I cannot believe how much of a hold that Satan has on our society, to be able to hide this super simplistic free energy technology + keep it hidden for so long. A ten speed bicycle should show us how simple this technology is. To only need to have the voltage=(electrical pressure) to rotate a 100cm circumference pulley one single time, and this giving you 100cm of moving belt. Then you run this 100cm length of belt past 10 min-pulleys of 1cm circumference, would give you an output of 1000 units of AC electricity,,, if you attached AC generators to these mini-pulleys.
THAT'S ONLY ONE SPARK OF DC IN, GIVING 1000 CYCLES AC ELECTRICITY OUT
How can you not gain a multiple of AC electricity
My type of free energy works on the simplistic reasoning of a 100cm circumference pulley only has to rotate once,(only costing one spark of current) to give you 100cm of moving belt. If you then run this 100cm of moving belt past 10 of the 1cm circumference pulleys, with AC generators attached, you would gain a multiple of 1000 units of AC electricity,,, all from one spark of DC current. With this kind of multiplication of AC cycles of electricity, wouldn't you have to gain, (multiply) your total energy output.
Yes, it is hard to fight against Satan + his evil spiritual forces, especially when this technology is so obviously logical. It only takes one spark of DC electricity to turn the motor over once + if you attach a 100cm circumference pulley to it, you would gain 100cm of moving belt. Then you run this moving belt through 10 mini=pulleys of 1cm circumference, with AC generators attached. This GEM= (Geographical Electricity Multiplier) would generate you 1000 units of AC electricity. Now,,, try and tell me that you cannot generate one spark of DC electricity, with an output of 1000 cycles of AC electricity. This is so dam simple, that it should prove to humanity that there is indeed a POWERFUL SPIRITUAL WARFARE going on over this technology.  http://free-energy.yolasite.com/
            This GEM mechanism works on the simplest of methods, by using variable sized pulleys, (simple mechanics) you can multiply your # of rotations, and with AC electricity more rotations means more AC cycles of electricity. Rotating one large 100cm circumference pulley on a DC motor only costs you one spark of current. Then, with the 100cm of moving belt that you get off this large pulley, you run this past 1 to 10 min-pulleys of 1cm circumference, giving you 100 to 1000 units of AC electricity, if you attach AC generators to your mini-pulleys.
            This AC electricity that you are generating with your mini-pulleys, only has to generate massive voltage, with practically zero current, as you only need one spark of DC current to have this a self powering mechanism. So, these AC generators cause practically zero torque, as torque comes from generating power = P=I*V, + since your current only needs to be one spark, practically zero, zero times massive voltage still equals zero. This massive voltage is what you need to crank over your DC motor the once, having the large 100cm circumference pulley attached.
            Of course there is one very simple missing part to this mechanism, it needs a full wave bridge rectifier,(4 diodes) to convert your AC output back into a DC input for your drive motor. Now, don't you think that 1000 units of AC electricity, would have the voltage to crank over your DC drive motor the one single time that it needs.
I have a person that has built three different models of these simplistic mechanisms, and says that they work great. But he has heard the horror stories about people who build free energy machines suddenly disappearing, and he does not want his name given out.
You wrote that this autor with this book has been your "key",let the forum decide that your view
is also their key or your behaviour only " a (bal)last" ,a kind of satanic=bad mis-/a-buse !
https://www.youtube.com/watch?v=LQPHgS7Cjv0
But you know that this bible(book of books) is not original,it is only a translated personal view from the
translator,often based by the Luther-bible,Wartburg/Germany.
An original bible is inexistant,"bible" is an archive of many pergaments roles by many mouth-2-mouth (hi-)stories.
And late: "GOD/DIOS/GOTT/DEUS was/is/will never be "MADE IN USA" or "MADE IN CANADA"
Copyright: Mesopotamien (Irak,Turkey,Syria,Lebanon,Israel)
What do you know really about the history,your or my ,what we have in common and what differ us ? You,your name Joe Lynch as delivered by your site are living in America,this continent from Alaska to Cape Horn baptizised honoring Americo Vespucci,italian carthograph.
You came from Halifax,Canada : Canada ,Labrador names given by Portuguese,in their language.
The life philosophy,the names,the languages, in the USA and Canada are often based by european-
mediterran fundaments and fundamentals-these often imported to Europe from the Asian hemisphere.
You write about many GODs,this is not right,physically, one "creation system" with many names in many languages and religions.
You can enter the www.epo.org site,you will see that many inventors soon before you ( or I) was borned by your mother(I by my mother) did invented and patented=publicated concepts based by pulleys/wheels motor/generator and so on !
Simple solutions but commercial not of interest. Simple truth. :)
                                              the truth: the priority date
            your "peers" are stealing the work honor of others,not fine,not to say satanic
that_prophet
AWE, COME ON PEOPLE, WE MUST SHAKE OFF SATAN'S ILLUSION.
This technology is the most super simplistic in its workings
You only have to gain the voltage=(electrical pressure) to rotate your DC motor the once,
If you attach a large 100cm circumference pulley to this DC motor,
This would gain you an output of 100cm of moving belt
+ if you ran this 100cm of moving belt through 10 mini-pulleys of 1cm circumference
You would gain a return of 10X100=1000 units of AC electricity
All for the input cost of one spark of DC current
Your AC generators run free, causing no torque, as they are just winding up massive voltage,
Which just happens to be exactly what you need, to crank over your drive motor
Massive voltage =(electrical pressure) to be able to crank over your one large pulley + many small pulleys
Quote from: pomodoro on May 18, 2015, 01:42:40 AM
LAST NIGHT GOD TOLD ME HE IS GETTING ANGRY WITH YOU. HE TOLD ME TO TELL YOU TO STOP THESE POSTS, OF FACE DAMNATION.
So please keep posting this shit , cause you deserve to rot in hell you dick muncher.
