Toroid-magnet-generator
Started by wizkycho, August 30, 2006, 06:26:18 PM
Low-Q
I have also tried to replicate this generator. The magnetic flux is just going through the part of the iron core where it is no coil when the coil i loaded. As soon as a coil is loaded, the coil starts to induce an opposite magnetic field. This field will force the magnetic flux through an alternative path. The only path available is the part in the iron coil where there is no coil. To generate some energy out, there must be at least two coils, two coils on the opposite side of the toroide. However, when the coils is loaded, the rotating magnet will slow down due to Lentz law. Lentz law will also work in a single coil toroide, but the law prevents any energy output instead of preventing the magnet to rotate.
Br.
Vidar
wizkycho
Hi All !
My prototype is finished. It looks like drawn in one of the previous posts.
There are lot of dissimilarities to original Grahmm generator. Allso the collector
on original machine is something to take into account...
Pictures,movie and testing after two week vacation.
What do You think If rotor (on my prototype) is not just magnets but added some of
permeable material (silicon iron in sheets preferably) ?
Lentz back force on rotor should be significantly lowered !!!
Output will remain same !?!
Has anyone tried something like that ?
graish-blue is core and permeable material
coils are not shown
Igor
Low-Q
The back torque will always be in relationship with the magnetic force. Applying iron to the magnets doesn't make any change in this relationship.
Br.
Vidar
wizkycho
Quote from: Low-Q on June 27, 2007, 05:28:16 PM
Br.
Vidar
It certanly does change
rotor's north at 12h. NO permeable material. coils are at left and right and loaded.
1.Lentz's created south (on one coil that magnet is going from) will drag back the rotor.
2.Lentz's created north (on other coil magnet is coming to) will push BACK.
So The Same undesireable direction forcing rotor back.
WITH permeable material (not satturated)
1.Lentz's created south (on one coil that magnet is going from) will drag back the rotor.(same as No per.mat.)
2.Lentz's created north (on other coil magnet is coming to) will drag FOREWARD.
So in a case with permeable material things do change with second force's direction, and this should
significantly lower back drag.
Please someone who has finished prototype and havent yet dismantle it , try it and inform us.
(In fact we should all keep our prototypes and not dismantle them even though they don't work at first, cause soon there can evolve some idea that will make them run - this of course requires some additional space)
best regards
Igor
wizkycho
Hi all !
...allso in progress
everything is allways in progress ...and there's no stopping
this is progression session in tha house
drumm and bass .... from The Space
Wiz
