1939 Gravity Power - multiply power by 1200%
Started by cipbranea, May 21, 2014, 01:38:08 AM
turbogt16v
I have just notice that the top rood(lever) the only one that is balanced is moving in circles and not just linear left to right.
Don't know if you already notice that ,if you see video 36 to 38 sec ,you will see shadow of the bar like its twisting.
Craigy
indeed ..the top plate with the smaller weight attached rotates around a central shaft,
The central shaft slides left and right...the centrifugal force developed by the smaller weight ensures that the shaft is pushed into each end of travel.
Any concepts or ideas expressed in this post are intended for the public domain. Free licence is given to reproduce and or modify provided it is for non-profit use. I don't want money, I want overunity!!
TechStuf
Quotenot been here for 5 years good job my password still works
i have started building a small model to undertand what is going on..I am more of a hands on person and that is the best way for me to learn and understand this mechinism.
I have a thought experiment..Imagine a child with effiel tower balanced on its peak, upside down. any input energy to move it off center is equal to the energy to return it to equilibrium..
Now while the device is chasing a continually moving center of gravity , how do we move the center of gravity without expelling the same amount of energy that is gained?
I believe that the secret lies in the centrifugal forces of the second weight. As it spins round and around, its centrifugal force is used to push the main shaft or axis back and forth in its slot..it is that "Extra Energy" that moves the axis, which allows a change in the position of the center of gravity..when you study the orbit of the smaller weight it is clear that it is creating a force vector in the direction of the slot, that vector reverses every 180 degrees..
the energy required by simply moving the center of gravity would cancel as per standard laws..but very little of the input energy is knocking the shaft off center , it is mostly centrifugal force doing the knocking..
I wonder if there are any springs on the sliding mechanism. since the centrifugal force could both compress springs and shift centers of gravity
my build to date
You certainly said a mouthful, and it's clear that you're on the right track.  At the rate you're going, it won't be long before you realize what Skinner was talking about when he stated that "improvements can be made".  You'll have the whole thing turned over on it's side before it's over.
Which won't be such a bad idea when the time comes....
Happy Trails,
TS
“For the wisdom of this world is foolishness before God. For it is written, “He is THE ONE WHO CATCHES THE WISE IN THEIR CRAFTINESS” - 1 Corinthians 3:19
http://www.freemasonrywatch.org/sixpointedstar.html
http://www.youtube.com/watch?v=XBjOs-egFMs
http://www.youtube.com/watch?v=_WSGwnz7XpY
http://www.youtube.com/watch?v=l39XsMcyvgA
http://portland.indymedia.org/en/2004/09/297062.shtml
http://www.youtube.com/watch?v=JjjIy1DO0gs
We all have the choice to waste ourselves in rebellion or to gain wisdom.  Therefore, gain wisdom:
http://www.hisremnant.org/eby/articles/kingdom/twohands/twohandsof.html
Craigy
http://youtu.be/n27XU9jXgxU
progress...ok i was only testing out my swash plate so don't go saying i got it wrong...lol need to power it up and then prony brake the output when the weght and its off center bearing thingy are added
i_ron
Quote from: gotoluc on June 07, 2014, 10:51:06 PM
The top is turning in a true circle as far as I'm concern, so wouldn't small bends in opposite ways to each end of the shaft allow the top to swing and base to stay true?
Luc
Hi Luc,
Couldn't resist a small demo myself... no output shaft but a bearing on the tilt plate to show that
there is no input from the shaft. Now I realise that W S's model has the weights fixed to the shaft
but this is more to keep all eight sections in sync, right?
https://www.youtube.com/watch?v=gTWwp5qUY3U
Ron
