1939 Gravity Power - multiply power by 1200%
Started by cipbranea, May 21, 2014, 01:38:08 AM
gotoluc
Starting to see some building action. Thanks for sharing Shylo and Craigy.
Today I was able to connect the upper shaft to the lower and found that the offset between upper and lower shaft I pointed out and incorporated in my build does not work if both shafts are centered.
That will delay the test by one day as I now have to go back to the welder to make a modification.
If I can get it welded tomorrow then I should be able to do the test and do a video by Tuesday.
Stay tuned
Luc
shylo
Hi All, was trying different weights ,turbo your right the build needs work, the bottom bearing blew apart, but only after I added a load.
The drive that enters the translation plate, needs to be fixed but offset, the lower needs to rotate in a fixed position. ( Artoj drawing is pretty much bang on , the early ones)
When adding a load, the lower shaft and weight slow down but will catch up if you add the load gradually.
My build is just for trying to figure out how everything works, not to put into mass production.
By adding extra weight the pressure on the lower bearing increased dramatically , This may be part of the reasons for having 4 offset weights , to distribute it evenly?
Thanks for your time. artv
gotoluc
Seems kind of quiet around here?
Got one video done but where I'm living at this time the internet bandwidth is very limited, so video uploading is very slow and can cut off at any time, then you got to start all over again. To help get it done I divided the video demo in two parts.
Here is the first part: https://www.youtube.com/watch?v=00xIxEQqRsk&feature=youtu.be
The next part may be in two hours or more. Also, this video is unlisted, so you need the link to watch it.
Luc
AB Hammer
gotoluc
Grease your pillow block around the edge. Otherwise nice construction. Looking forward to your test.
Alan
Alan
gotoluc
Quote from: AB Hammer on June 17, 2014, 08:34:23 PM
gotoluc
Alan
Do you think grease will work better than oil?
Luc
