1939 Gravity Power - multiply power by 1200%
Started by cipbranea, May 21, 2014, 01:38:08 AM
centraflow
PSS.  the center of gravity that moves in relation to the bottom weight is where the rod connects to the transition plate, from here it is to the top of the bottom weight and from there to the CV joint, it is triangular and moving infinitum in one revolution.
regards
Mike 8)
centraflow
I should have written that pdf Luc ::)
Note that the top of the bottom weight is exactly at the same level as the bottom of the top weight, I think this is important
regards
Mike 8)
centraflow
Luc you can skype me if you want, maybe easier.
regards
Mike 8)
gotoluc
Quote from: centraflow on June 18, 2014, 12:09:54 PM
PS.  the lever drive is eliptical and not circular
regards
Mike 8)
Thanks for your posts Mike
Have you seen this video loop: http://www.overunity.com/14655/1939-gravity-power-multiply-power-by-1200/dlattach/attach/138942/
I posted back on page 6. If you look at it on full screen you can clearly see a fixed point arm rotating the upper lever in a circular motion.
Luc
centraflow
Yes I have, but that is a long lever, pivoting bar, with a cam on each end, this is because the rod has a circular movement, free movement, as I have shown in my diagram.
I will draw that top part and then you will see it, it is what gives the eliptical shape to the gimbal
regards
Mike 8)
