1939 Gravity Power - multiply power by 1200%
Started by cipbranea, May 21, 2014, 01:38:08 AM
centraflow
The top two sections are like sling shots (i'm using the term loosly), all to change that lower center of gravity with nearly no force at all.
regards
Mike 8)
centraflow
Bad drawing in a hurry, but I think you will get the idea, this is the final stop to the drive seeing the output
regards
Mike 8)
centraflow
wow I did draw that badly, sorry about that ;D
regards
Mike 8)
centraflow
once the top weight is moving, the only drive power is used in moving that beam back and forth, and no more, it is that simple
regards
Mike 8)
gotoluc
Hi Mike,
I'm quite positive there is no bearing in the mid plate for the upper lever. you can see he has a set screw where the lever enters it.  Have a look at the attached video. You can see the lever is turning exactly with the mid plate, so why have a bearing there when one is at the top of the lever and obviously one in the gimbal?
While you're viewing the video, notice the left lever is swinging in and out as much as the front lever is swinging side to side. I my view this strongly suggest the leave motion is circular.
I'm not trying to contradict you, just bringing to your attention what I have been observing for quite some time.
Luc
