1939 Gravity Power - multiply power by 1200%
Started by cipbranea, May 21, 2014, 01:38:08 AM
2020man
THANKS so much for doing this! Very helpful. Very encouraging.
But friction will be irrelevant with such a high gain . . .
Best wishes
2020
thngr
How come so easily made mistakes to overcome our wishes?
2020man
Quote from: thngr on November 03, 2014, 05:03:18 PM
some little math on it...
I can't find the post I saw last night redoing this analysis showing COP=1 . . . Which represents the reality?
My gut feeling is that the top of the pole must be directed and not driven, simply loosely following the motion of the arm so that the weight does its work in wanting to fall and the top of the shaft is merely preceding the position to maintain that situation. As the weight wants to fall the top of the shaft should want to move forward and so not provide a backwards force causing work to be needed to be done . . . so no energy input at the top . . . ?
Best wishes
2020
MoRo
Quote from: 2020man on November 04, 2014, 03:06:04 AM
Best wishes
2020
The weight will merely pursue balance at a lowest point. It does indeed require energy in the form of torque to rotate the top of the rod around a center point, to cause the imbalance which the weight will continue to pursue. (see my earlier post)
ARMCORTEX
The device never worked, video and claims were wrong.
Who is to blame for all this commotion ?
