Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
Then please go ahead and explain the black voids (still waiting) and the egg-shaped void.  I am very curious to hear your explanation and perhaps others are too.
TheoriaApophasis
Quote from: john_doe on July 17, 2014, 10:24:30 PM
Although they simply call it "Big Bang Theory". Yes, the fact the universe is expanding at an ever increasing speed confirms OverUnity to me.
Actually it only confirms my discovery about 10 years ago of  1/(1/Phi^-3)
TheoriaApophasis
Quote from: MileHigh on July 17, 2014, 10:35:13 PM
Then please go ahead and explain the egg-shaped void.  I am very curious to hear your explanation and perhaps others are too.
Well, Im an idiot, right?   You have your force vector formula for the calculation.
Im waiting for the Cult of Quantum to spit out answer.
I just DID explain the dielectric displacement ("black void") above.  Im glad you missed it on purpose.
talk of electrons?  Whats this nonsense?   ;D  ;D
J.J. Thomson concept of the "electron" (his own discovery). Thomson considered the electron the terminal end of one unit line of dielectric induction.
     "Unfortunately to a large extent in dealing with dielectric fields the prehistoric conception of the electro-static charge, the 'electron', on the conductor still exists, and by its use destroys the analogy between the two components of the electric field, the magnetic and dielectric. This makes the consideration of dielectric fields unnecessarily complicated" - C.P. Steinmetz (Electric Discharges, Waves and Impulses)
     The idea of electricity as a flow of 'electrons' in a conductor was regarded by Oliver Heaviside as "a psychosis". This encouraged Heaviside to begin a series of writings
     "Electrons as a separate, distinct entity...doesn't really exist, they are merely bumps in something called a 'field'."  - Dr. Steve Biller
Nature is not governed by the irrational pontifications of GR and QM, rather it is governed by mutually interactive reciprocal conjugates of charges-discharges, centripetal-centrifugal movements, both spatial and counterspatial. Instantaneous action at a distance, and fields are all Ether modality mediations as propagated by counterspace-in-disturbance, the Ether, its pressure gradients and perturbations. No other mediator can be logically hypothesized, much less theorized. The very same Ether of Tesla, Heaviside, C.P. Steinmetz, and even originally from Einstein before logic fled his mind completely, was correct and remains so. Tesla outright denied our current definition of the electron as a 'discharge particle'.
     All electrons are a motional terminus of a quantity of dielectric pressure gradients of force (as reified by the incorrect understanding of the definition of a 'field'), these pressure gradients, or "lines" are contracting and stretching like rubber bands, giving motion to the terminus 'electron'. The thermionic 'electron' contracts, pulling the 'electron', the cathode ray stretching, pulled by the 'electron'. In the former case the lines of force are dissipated, in the latter case the line of force are projected, in both cases these so-called 'electrons' assume radial motions, with non participating pressure gradients, or forces filling the 'voids', directing the 'electrons'. Hence, it is the so-called 'electrons' (dielectric radial discharges) that travel in straight lines, that is, radially. 'Electrons' have nothing to do with the flow of electricity; the so-called 'electrons' are the rate at which electricity is destroyed. 'Electrons' are in fact the resistance. From extensive experimental work into atomic electrical science by J. J. Thompson, and Nikola Tesla, it is established that the so-called electron is only a shadow; its apparent-only physical mass is merely an electrical momentum (ejected by the dielectric inertia in disturbance). There is no rest mass to an electron nor could there be logically, a rest-electron 'bead'; such notions are absurd and evidence proven non-existent. The very premise is logically impossible and contradicts the rational physics of atomic charges and discharges.
     There is no such condition in nature as a negatively charge particle nor could there be. Charge and discharges are opposite conditions of a single subject, either protons or fields of movements and radiation of those same electrical fields. To claim that liquid in a jar (charged) is one thing, and pouring that liquid from the jar (discharge) is another liquid altogether, is nonsense, likewise compression and expansion are opposite conditions of a single subject. Compressing bodies are charging into higher potential conditions. Conversely, expanding bodies are discharging into lower potential conditions.
     "To describe an electron as a negatively charged body is equivalent to saying that it is an expanding-contracting particle. There is no such condition in nature as a negative charge, nor are there negatively charged particles. Charge and discharge are opposite conditions, as filling and emptying, or compressing and expanding are opposite conditions."
     "Here we will dispel the "electronics nerd" concept that a capacitor stores "electrons" in its plates. Taking the pair of copper plates as in the previous experiment, but now we have two pairs of plates, one pair of plates distant from the other pair of plates. Upon one pair of plates is imposed an electro-static potential between them. The cube of 10-C oil is inserted between this "charged" set of plates. This hereby establishes a dielectric field of induction within the unit cube of 10-C oil. Now we then remove this cube of oil, withdrawing it from the space bounded by the charged pair of copper plates, and taking this unit cube of oil, it is then inserted into the space bounded by the other uncharged pair of plates. Upon insertion it is found that the un-charged pair of plates have now in fact become charged also. It here can be seen that a cube of dielectric induction can be carried through space, from one set of plates to another set of plates."
Youve been drinking the Kool Aid of Quantum, son.   Its nothing but Greek Atomism
Unicorn particles
Pixie particles that discharge
Pure irrational insanity, thru and thru    ::)  ;D  ;D
Well, "dielectric displacement" does not cut it as an explanation for why we see the black void.  Please give a real explanation that explains the phenomenon with some details.  Demonstrate competency in the subject matter.
TheoriaApophasis
Quote from: MileHigh on July 17, 2014, 11:00:48 PM
Empty claims, Its like eating sponge cake, you know theres something there, but nobody likes it.
Too bad too,  it  "CUT IT" for Tesla, Faraday, Maxwell, and Steinmetz
Since you dont experiment, let me educate you a bit son.
buy an electrostatic generator, and sprinkle graphite on the charged surface, then bring a magnet near it.
I assume (correctly) in your insanity that you dont know that a supra-diamagnetic material is ANTI-magnetic.
Let me translate that for you in a way your mind can understand  Diamagnetic = super-dielectric = anti-magnetism
Son, how did you think a Yttrium barium copper oxide disk at temp of LN2 (liquid nitrogen) levitates a magnet?  It becomes supra-diamagnetic.
Back to school with you.
  Suggest you go read Heaviside, certainly JC Maxwell
