Hi Jimboot:
I can't comment because there is not enough information.  If you want to make a sketch a decent amount of detail in it and then describe the setup and make your question clear I will try to answer.
There is a phenomenon of being inside your "own bubble" at play here and it's a very common thing.  When you are inside your own bubble the question seems to be clear and obvious and makes sense.  For people outside the bubble things are not nearly as clear and obvious.
Jimboot
Quote from: MileHigh on December 10, 2014, 06:34:17 AM
Hi Jimboot:
Totally agree mate. That's why I'm looking for more input. I've built a much better rotor since this vid https://www.youtube.com/watch?v=v_Kf5RsTGZ4 but it will give you an idea what I'm talking about. Just trying to understand where lenz should be in that config.
Quote from: T-1000 on December 10, 2014, 06:34:07 AM
MH,
http://overunity.com/15083/the-new-generator-no-effect-counter-b-emf-part-2-selfrunning/msg426103/#msg426103
Make a pendulum model, study its behavior on coil shorting then start opening circuit when iron bar is approaching coil and short it when it is under coil. After seeing what it does we can spend more time on discussion...
Do you have a link with a description of what is going on in your diagram?   What about the claims you are making, do you have a link or can you state the claims here?   Do you have any pictures of a real setup or some YouTube clips?
Jimboot
Quote from: Erfinder on December 10, 2014, 06:45:34 AM
A proper examination of the above, supported by a little bench work will reveal a great deal.  When the comparison is made, it becomes clear which mode to use, and after a little quiet contemplation, one begins to understand which is better suited for generating, and which is better suited for motoring, there is a difference.
One thing I note with regards to folks researching in this direction is that most have a more or less straight forward approach to motors, the problem is seen in that they take nothing that they learn from their experiences with motors and apply it to generators.  This implies many things, I hope this changes in the future, there are so many clever individuals here....spinning their wheels, burning rubber.....
I have a dynamo here that is same poles facing. However I'm thinking the phenomena requires alternate poles to cause the generation effect that I'm seeing. I haven't tested sames poles facing though
T-1000
Quote from: MileHigh on December 10, 2014, 06:42:37 AM
No time to waste, you have to experience in first hand on experiment before exchange of videos happen.Especially when 2 pages of your posts in this thread is just talk...
