T-(Shaped) Turbine, Which uses Centrifugal Force
Started by Overunityguide, December 24, 2014, 05:49:39 AM
Overunityguide
Kator01
Hello overunityguide,
self-accelleration can only happen if tangential forces are allowed to develop.
This concept was proposed some years ago by Alan Cresswell, see fig. 11
http://web.archive.org/web/20120825053539/http://www.unifiedtheory.org.uk/
I lost contact to Alan and I think he died.
Kator01
Overunityguide
After a lot of testing over the last two weeks, I think that there might be an overseen issue related to the Coriolis Effect taking place inside the T-(Shaped) Turbine. I say this because it looks like when the T-(Shaped) structure is rotated, that there is a higher Counter Force resisting rotation, when there is a higher Water Flow Rate.
I also found a couple of video's demonstrating this effect...
Coriolis Flow Meter Demonstration:
https://www.youtube.com/watch?v=vxI9ibhVND8
https://www.youtube.com/watch?v=NpX9oXsbOfw
How Coriolis force affects a centrifugal pump:
https://www.youtube.com/watch?v=bz0rWdn09sM
Visualization of the Coriolis and centrifugal forces:
https://www.youtube.com/watch?v=49JwbrXcPjc
vineet_kiran
Quote from: Overunityguide on January 05, 2015, 08:58:12 AM
What happens if you use air as working fluid which has negligible mass compared to water?   I think using thin light piston with air as working fluid can eliminate the Coriolis  force.
Please have a look at this experiment.
http://overunity.com/13489/centrifugal-overunity-an-imaginary-experiment/msg359724/#msg359724
Overunityguide
Hi vineet,
To eliminate the Coriolis Effect from taking place, I am thinking more of building a Spiral Like Arrangement at the moment. Just like Viktor Schauberger has created in the past... (Please see my attached Spiral-(Shaped) arrangement test setup) I am also planning to do another video about it.
