0 Members and 70 Guests are viewing this topic.
Quote from: ayeaye on October 16, 2015, 12:51:49 PM
So, do you say that these bucking coils one on another induce opposite magnetic fields simultaneously in the core? If so then, what comes to my simple mind, is it possible that these opposite magnetic fields somehow prevent each other from decreasing, and this increases induction. If so, then it is very interesting.
No, in fact the opposite magnetic fields simply cancel each other out.  That reduces the measured inductance.  It's highly unlikely that Tinman did not note the way the coils were wound.  Because of the way the device is made, "aiding" is more of a "bucking" configuration and "bucking" is more of an "aiding" configuration.
partzman
Side stepping for a moment the loaded analysis as MileHigh has done with some measurement recommendations,  since the open circuit secondary voltage is 2x the primary, would this not require 2x flux in the secondary with the turns being equal?  If so, how is this being created?
I am not that familiar with it, but is anyone up to a FEMM analysis of the magnetic circuit?
partzman
poynt99
Smudge might be able to shed some light on this.
Perhaps examination of the equation for the approximate inductance of a toroid coil may be revealing...
L ~ uN2A/2PIr
where:
u= permeability
N= number of turns
A= cross-sectional area
r= toroid radius to center line
If we assume that everything remains equal between the primary and inner secondary (including A), then as r is much smaller for the inner secondary, L will be larger.
partzman
Quote from: poynt99 on October 16, 2015, 05:34:30 PM
L ~ uN2A/2PIr
where:
u= permeability
N= number of turns
I have PM'd Smudge as I see he is a member here.
Tinman, it would be nice if you would document the dimensions for the inner and outer cores so a model could be made in Femm.
Also, out of curiosity, have you taken any input/output efficiency measurements?
partzman
tinman
Quote from: partzman on October 16, 2015, 08:02:07 PM
partzman
QuoteAlso, out of curiosity, have you taken any input/output efficiency measurements?
I have  ;)
But i first need to make myself another isolation transformer for my scope,as the UPS is now RS.
I want to remove the common ground between the scope and SG before i post any results,as something is not right here. I have a feeling the common ground is throwing out the measurements on the scope some how.
