0 Members and 101 Guests are viewing this topic.
EMJunkie
Quote from: seychelles on December 14, 2015, 07:02:43 PM
Chris the way i would do this experiment is like this.
1 Use an electric kettle of a know power consumption.
2 one litre of distill water
3 an accurate thermometer
4 one electronic power meter.
Fill the kettle with 1 litre of distill water.
put the kettle in the freezer with the thermometer monitoring the
water temperature. W
Hey Seychelles,
Yeah, not a bad experiment, the only Problem I see is that Cold Water Currents vs Warmer Water Currents, hotter on the top and cooler on the bottom, so getting an even heat distribution would be hard and give rise to error.
But a good recommendation.
   Chris Sykes
       hyiq.org
seychelles
Chris this is just the cheap way out. BUT when you think you have a super
result.. THEN  you let it be known and pass it on to a university so they can really
asses it as per quot.
EMJunkie
Quote from: seychelles on December 14, 2015, 07:28:50 PM
Hey Seychelles,
With respect, you've missed the boat I think... Maybe that's the problem with this thread... Maybe everyone has missed the boat except for the few successful replications that have been reported...
Thay tried to tell you the same thing:
Quote from: Thaelin on December 09, 2015, 02:16:31 AM
Yuri did what I did, and got the same results. It baffels you to see it.
Even worse, is when you try to prove yourself wrong and the results hold rigid.
Now lets see how bad the pack tears this one up.
Let me put it into a one liner:
Three Coils, wound, wired and configured correctly, can give you OVER-UNITY
I am sorry, but if all of you want to see Over-Unity then you need to see it for what it is! If you pay close attention, I show you exactly the concepts on how to do it here: Self Assisted Oscillation in a Shorted Coil - Bucking Magnetic Field Oscillation
If you want it, you have to pay close attention, a little work is necessary!
   Chris Sykes
       hyiq.org
EMJunkie
Do yourself a favor, ask yourself, what will happen when these Coils, Partnered Output Coils, carry a Current?
The Answer is here: Self Assisted Oscillation in a Shorted Coil - Bucking Magnetic Field Oscillation
   Chris Sykes
       hyiq.org
wistiti
Please Chris do not "burn" yourself in explanation with those who just whant to theorise... They have much to realise of the "strange" things happen with the POC if they built it...
And then, share our BUILDERS experiment may be the way to go. ;)
