0 Members and 39 Guests are viewing this topic.
EMJunkie
Quote from: hanon on January 21, 2015, 04:03:33 PM
Chris, You were talking about using plastic spacers between cores and now it seems that just adjusting the coil spacing (distance) is fine to get the effect. Please define what you call "loose coupling". What is really required to replicate this device? My impression is as there is still information that you have not defined.
As a suggestion if you want to avoid going into hard discussion you should avoid agressive sentences stating that you measures are not here to be debated. Do not feed these discussions.
Hi Hanon,
Plastic Spacers ARE needed in the second configuration that I have shown. Not the first.
If I may suggest a re-read of the posts I have posted. I have covered this already! This is also covered in the pdf!
Kind Regards
   Chris Sykes - hyiq.org
   To Reach New Horizons!
PIH123
Quote from: EMJunkie on January 21, 2015, 04:32:12 PM
@PIH123
Scope was AC Coupled @10 per div. The Output is AC on this device, not DC. Input is chopped DC, Bi-Polar via a H-Bridge, which is also considered to be AC, just a AC Square wave.
Kind Regards
Thanks, that info helps.
So for anyone testing this, apparently, you should see no difference whether your scope is AC or DC coupled.
In which case, best testing practice would say make sure it is DC coupled on both channels so you won't miss anything unexpected.
EMJunkie
Hi PIH123,
Quote from: PIH123 on January 21, 2015, 04:42:59 PM
No - This is not what I said! Please Re-Read the post.
It depends on the setup. If the Output is AC then AC is needed on the scope. Vice Versa...
No, again I disagree!
"In alternating current (AC), the flow of electric charge periodically reverses direction." - A H-Bridge can Chop the DC and the flow of electric charge periodically reverses direction.
Ref: http://en.wikipedia.org/wiki/Alternating_current
This is just common-sense, so please don't try to confuse others here!
Kind Regards
SkyWatcher123
Hi folks, Hi emjunkie, well just fired it up and i am using an led bulb to see if it can power things, it lights the led bulb well.
When i use a wire to short the partnered secondary coils, the amp draw lowers from 360 milliamps while powering led bulb down to 260 milliamps using 3.7 volt input.
My other setup did not do this when a dead short was applied across partnered coils.
So does this sound like the right behavior so far, emjunkie.
Here is a pic of it.
peace love light
EMJunkie
@ALL,
There is MORE than enough information, that I have provided, to make this work. For those that want to do it, I suggest to go ahead and do it. I don't have the time or the want to put up with people that are just time wasters! They could have done ten experiments by the time they write rubbish and post it publicly to disrupt and distract. We got 5 Pages in before they came!
Again, I point those interested to the First Post:
Data: http://www.hyiq.org/Downloads/Guidelines%20to%20Bucking%20Coils.pdf
Video 1: https://www.youtube.com/watch?v=iJsVSMQqCOM
Video 2: https://www.youtube.com/watch?v=ZhQgch4L5XY
Video 3: https://www.youtube.com/watch?v=zSadMqEnO7I
Video 4: https://www.youtube.com/watch?v=Z-V1z2TdQJA
Also Required Study: https://www.youtube.com/watch?v=lcGWO_x8tpM and https://www.youtube.com/watch?v=U9m86joRSMg
For those that want to disrupt and distract, write rubbish on a public thread, ALL with no proof, no experiments to back them up, and not real information to dispute other wise, go ahead!
Kind Regards
