Friedrich Luling Magnet Motor
Started by DreamThinkBuild, July 05, 2015, 05:31:08 PM
knovos
took some parts away to show the magnet block better
rstergar
Hello, long time out of this project :)
Now i see you came with new idea and I was thinking how to get rid of an air mechanism and let the motor do the job by itself...
I find some idea worth trying, because its very plausible... here is animation: https://youtu.be/4EwS92NLLgw
and here is image...
If I will have time I will try to build this ;)
Best regards from Slovenija
Ufopolitics
Hello,
It is great to see you are working on this project, at least in Graphics...
I will give you some tips about your above graphic plus your video...
You can NOT add any more magnets around the adjusting magnet!!
By doing this you will immediately break Neutralization, becasue of other magnetic Fields distorting the Neutralization Effect.
So, no, you can not use but JUST the Magnets that are INVOLVED in the Neutralization.
Otherwise it will kill it, and it may try to find its own neutralization "naturally" like magnets always do.
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
Ufopolitics
Some common Info about Magnetic Neutralization:
FACT 1: Magnets, always try to find their own "Stabilization", or We could call it also "Neutralization"...if they are thrown randomly and loose, they will turn around, and end up sticking all together...or even fixed and set in a Rotor and Stator...they will always find the "Spot" where they will stick...and motion is finished.
FACT 2: We MUST FORCE our own Neutralization, by following the Graphics I have rendered before.
And You could add more magnets, as long as they are set in PAIRS of Attract-Repulse SETS, exactly at 180º EACH PAIR.
Ufopolitics
―Leonardo da Vinci
knovos
I think I have it all worked out (digital). I had printed out a few parts but when you finally have them in your hand you often see whether it will work or not. The parts shown now are therefore thicker and stronger. I also had to come up with something else for the push disk. This can now be adjusted at the right time and a second can easily be added. I also made an adjustable distance on the stator side to be as flexible as possible, there is of course no push disk on the stator.
