Friedrich Luling Magnet Motor
Started by DreamThinkBuild, July 05, 2015, 05:31:08 PM
dieter
The weight, fixed over a rigid rod, would also and especially prevent the floater to flip over.
all PM levitation is possible, but difficult, just like placing a soccer ball on a piece of fluffy rubber foam. Although I don't see any first law violation, and I'd be surprised about that constant vibration thing since I'd rather expect it to settle down at the equilibrium.
A Microwave oven magnet may be used to repell the floater magnet. If the repulsion is strong enough for both, floater and the mentioned weight.
rstergar
hi everyone
after reading about this motor and do some tests I decided to try build one because after testing when magnet is surrounded by steel there is almost no attraction force anymore so I think 90% that this might work :)
will update soon...
rstergar
update:
currently done 80% :)
the attraction between magnet and steel plate which demagnetize a magnet is lower than i thought. it will easily move with the spring which pull it back while operate...
https://youtu.be/FZ0kX6kBVfY
PolaczekCebulaczek
Quote from: rstergar on April 23, 2017, 06:44:53 AM
update:
Excellent work!, keep going, your setup look really awesome and solid. The Luling motor is the only one that i found worth a build.
rstergar
Thank you :)
But this model will not work because I must start over and create it more precise and with better materials than plastic...
Here is my new idea of design: https://youtu.be/oAvcmSFOfns
I will start ASAP...will update here ;)
