New gravity motor from China
Started by hartiberlin, November 01, 2006, 11:53:37 AM
hartiberlin
Hi,
yes, this is a very good idea !
Only 2 shutting plates needed !
One at the top and one at the buttom of the water tube !
When the float is inside the tube, you shut the lower plate and
open the upper plate and voila the float rises to the top
and can exit easily and fall down again on the chain.
Then first the upper plate has to be closed again and then the lower
plate has to be opened again.
This will be a working gravity mobile !
Dingus Mungus
Dingus Mungus
Because of the fast fall time in air and slow rise time in water you will need an excess of "float weights" in the tube ready for the chain. I would assume with good timing on the valves and enough "floating weights" in que the concept would be a self running device.
FreeEnergy
hehehehe!!!!!!!!!!!!!!!!!!!!!!!!!!!
