use pulleys to multiply total # of rotations = AC electricity
Started by that_prophet, July 02, 2016, 11:35:19 AM
that_prophet
At zero operating cost, we could be sharing our electricity with our neighbours,,, or making some extra money on the side, by selling any extra electricity back to the electric utility grid, wouldn't that be awesome,,, lol. It could be very profitable to make as many of these miraculous mechanisms as we can, and selling it back to the power companies.
Speaking of sharing,,, let me share something about this Israeli peace process,,,
That we are hearing about on + off, and will continue to hear more about, as the time gets nearer.  We are warned in the Bible "of that day and hour knoweth no man"-(Mat 24:36),,,
But we are also blessed with being told, that we can know "that it is near, even at the doors". (doors here are plural, to accommodate both of His Arrivals,,, once in the clouds, to rapture all His Born Again followers,[before the treaty is signed] and then again when He sets his Feet on the Mount of Olives,[at the end of the treaty]) http://rapturequestion.yolasite.com/
We can calculate the dates that these doors will shut, by knowing it will still being able to happen within our generation, which started in 1967.44, when Israel took control back of Jerusalem. This must have happened because the Jews had to be in control of Jerusalem, to continue the final 7 years of the prophecy about their 70 X 7, because the 70 7's was a prophecy about Jerusalem, as well as the nation of Israel. Israel took control back of Jerusalem in 1967.44 + 51.6(calculated from 14, 14+14 generations of Christ's linage) = 2019.04 is when the first Door shuts. SO,,, ISRAEL'S 2520 DAY PEACE TREATY MUST BE SIGNED BY OR BEFORE 2019.04 + (.04 X 364.25 = 14.57) OR  January 14, 2019 is the date of when the door closes, on the prophecy about the 70X7's.
Now, I know that there could be many durations for this last generation, but I feel that this 51.6 years duration is best, as not only was it calculated from the linage of Jesus, from the birth of Abraham
I've always called this whole 7 years the tribulation, but I have just recently learned that only the last half is the Great Tribulation.
http://doorschristmustpassthrough.yolasite.com/
http://2020vision.yolasite.com/ My other one, a better written site about the 20-20 Vision that He Shared with me, seems to have a bug in it, and is transferred out of immediately.
I thought that we Christians wanted Christ to come back......
2 things are needed before He arrives both times.
-   First His Bride MUST prepare itself to be spotless,,, before He arrives in the clouds, to rapture us.
o   Elijah MUST return + fix things in Christendom
-   Then Israel MUST accept + ask Jesus back, before their King Returns to earth,
http://beliefstoliveby.yolasite.com/
Students could build these GEMs to supplement income + to not only stop paying electric bills, but they could be adding power to the grid, and making money off these simple + easy to build GEM devices
that_prophet
free energy is done using pulleys
It uses the simplicity of it not taking 100 times as much force turning a 100cm circumference pulley, as it does turning a 1cm circumference pulley, yet you get 100 times more LENGTH OF MOVING BELT to work with. If you run the 100cm of belt by any # of 1cm circumference pulleys, you would gain the # of mini-pulleys times the multiple of 100 units of AC electricity.
THAT IS WHY I CALL THIS AN AC ELECTRICITY MULTIPLIER
that_prophet
citfta
It's too bad people that are mentally ill can't recognize their mental illness.  Mental illness it the only reason I can come up with for a person to keep posting the same thing over and over and over in almost every part of this forum.  I guess every forum has to have at least one of them.
that_prophet
The full explanation of GEM=(God's Electricity Machine)
I truly do not understand the mass misunderstanding here, can't you see that evil forces are at work, keeping you from believing this Gracious Gift of God's. This was easily understood by everybody that I told this to, and they agreed that it was so obvious, that it just had to work. I will try to explain it in the same way, that I explained it to them.
            I started off by telling them that I had a large 100cm circumference pulley, and that it was connected to a DC motor. Then I told them that it only took one single spark of DC current, to rotate that large 100cm circumference pulley one full time. This would give you 100cm of moving belt, which you could then run past 1 to 10 mini-pulleys of 1cm circumference. This would give you an output of 100 to 1000 units of AC electricity, which you would run through some full wave bridge rectifiers,(4 diodes): one for each AC generator that you are using. This way you would get a lot more DC current than you would need to power your DC motor for one rotation.
           Now, try and tell me that you could not get the one spark of DC current, that you needed for your input drive motor, out of the 1000 units of AC electricity that you get as an output. Thus, you have a set of AC+DC motors/generators that run continuously, that you should be able to tap power off of, and the greater the # of mini-pulleys with AC generators attached, they greater the amount of current you should be able to coax out of you leads off of your full wave bridge rectifiers.
http://free-energy.yolasite.com/
This was given to me for the Tribulation Saints, (I ask my ABBA Father)
+ I don't think that they will have money to buy all of these items.
When this is meant to be super simple + easy to build out of odd spare parts.
All that you need is a DC motor + an AC generator of the same voltage.
One large wheel/pulley, (like a bicycle rim) + at least one mini-pulley/wheel, (a thread role)
And a few full wave bridge rectifiers = (only 4 diodes each)
The hard part is when you would have to rig up a way to connect your motor + generators to your pulleys, (glue or threading of some sort,,, you cannot weld or bronze them, unless you found a way to disassemble them or heat sinks, to keep from frying your winding's)
Myself, I cannot believe how much of a hold that Satan has on our society, to be able to hide this super simplistic free energy technology + keep it hidden for so long. A ten speed bicycle should show us how simple this technology is. To only need to have the voltage=(electrical pressure) to rotate a 100cm circumference pulley one single time, and this giving you 100cm of moving belt. Then you run this 100cm length of belt past 10 min-pulleys of 1cm circumference, would give you an output of 1000 units of AC electricity,,, if you attached AC generators to these mini-pulleys.
THAT'S ONLY ONE SPARK OF DC IN, GIVING 1000 CYCLES AC ELECTRICITY OUT
How can you not gain a multiple of AC electricity
My type of free energy works on the simplistic reasoning of a 100cm circumference pulley only has to rotate once,(only costing one spark of current) to give you 100cm of moving belt. If you then run this 100cm of moving belt past 10 of the 1cm circumference pulleys, with AC generators attached, you would gain a multiple of 1000 units of AC electricity,,, all from one spark of DC current. With this kind of multiplication of AC cycles of electricity, wouldn't you have to gain, (multiply) your total energy output.
Yes, it is hard to fight against Satan + his evil spiritual forces, especially when this technology is so obviously logical. It only takes one spark of DC electricity to turn the motor over once + if you attach a 100cm circumference pulley to it, you would gain 100cm of moving belt. Then you run this moving belt through 10 mini=pulleys of 1cm circumference, with AC generators attached. This GEM= (Geographical Electricity Multiplier) would generate you 1000 units of AC electricity. Now,,, try and tell me that you cannot generate one spark of DC electricity, with an output of 1000 cycles of AC electricity. This is so dam simple, that it should prove to humanity that there is indeed a POWERFUL SPIRITUAL WARFARE going on over this technology.  http://free-energy.yolasite.com/
            This GEM mechanism works on the simplest of methods, by using variable sized pulleys, (simple mechanics) you can multiply your # of rotations, and with AC electricity more rotations means more AC cycles of electricity. Rotating one large 100cm circumference pulley on a DC motor only costs you one spark of current. Then, with the 100cm of moving belt that you get off this large pulley, you run this past 1 to 10 min-pulleys of 1cm circumference, giving you 100 to 1000 units of AC electricity, if you attach AC generators to your mini-pulleys.
            This AC electricity that you are generating with your mini-pulleys, only has to generate massive voltage, with practically zero current, as you only need one spark of DC current to have this a self powering mechanism. So, these AC generators cause practically zero torque, as torque comes from generating power = P=I*V, + since your current only needs to be one spark, practically zero, zero times massive voltage still equals zero. This massive voltage is what you need to crank over your DC motor the once, having the large 100cm circumference pulley attached.
            Of course there is one very simple missing part to this mechanism, it needs a full wave bridge rectifier,(4 diodes) to convert your AC output back into a DC input for your drive motor. Now, don't you think that 1000 units of AC electricity, would have the voltage to crank over your DC drive motor the one single time that it needs.
I have a person that has built three different models of these simplistic mechanisms, and says that they work great. But he has heard the horror stories about people who build free energy machines suddenly disappearing, and he does not want his name given out.
Quote from: citfta on September 17, 2016, 11:29:24 AM
