Dual energy generation with magnetic seesaw system and gravity
Started by vikram_gupta11, August 15, 2016, 06:12:34 AM
Low-Q
Thanks for the explanaton, and I look forward to see your design :-)
I have approx:
100 pcs 26mm diameter, 6mm thick, N50, magnetized through thickness.
18 pcs 50 x 5 x 1.6 rectangular N50, magneticed through thickness.
A bunch of 10mm diameter, 3mm thick, N40, magnetized through thickness.
And some different small magnets extracted from dead brushless motors.
So I have a few magnets to play with. If your design work as big size, it should work as small size so it is easier to manage, and put together.
Those 26mm diameter magnets are BAD. I can't count how many times I have been bleeding from pincing my fingers with these.
I have not measured how much weight they can lift, but the small 10mm diameter magnets can lift a 2.5kg sledge hammer with ease.
If I must print some parts on the 3D printer, the maximum size is 200mm x 200mm x 170mm.
Hope this information helps.
Vidar
vikram_gupta11
dear Sir, Thank you for your reply . I will send you more details very soon.
thank you Sir
gyulasun
Dear vikram_gupta11,
I would like to draw your attention to a youtube video referenced in this thread here:
http://overunity.com/16847/gravity-energy-i24news-israel/msg491195/#msg491195
The reason is that I think the principle involved in the video is similar to your device principle shown in this thread: to keep a balanced seesaw system in motion with a small amount of input energy while utilizing possible output energy of the system by appropiate ways. The difference is that in the video above the output energy is taken from piezo electric devices that are pressed as per the seesaw structure moves back and forth.
Please do not shoot the messenger...  :D no bad intentions involved.  Looking forward to your progress here and I wish you good luck.
Greetings
Gyula
vikram_gupta11
Dear Mr. Yulasun ,
this is completely different  than My concept. They  cannot generate more out put than input and technics are different.
vikram_gupta11
Dear VIdar Sir,
I'm sending you some details regarding this concept.
As per sketch we will take a SEESAW system and will attach 50 kilogram weight on the both side of this SEESAW system so that this seesaw will get equilibrium state.
Now we will take four  strong NEODYMIUM magnet and attach each  magnet with each 50 kilogram weight .This 50 kilogram weight will be in RECTANGULAR shape.we will attach these magnets on the lateral surface of 50 kilogram weight.
this 50 kilogram weight will not movable only seesaw 's arm will move .This 50 kilogram weight will be fixed permanently with both arms of seesaw system.
Now we will take two small 800 gram weight and will attach four low power Neodymium magnet with this weight. These weights will move on a inclined(8 to 10 degree)  track system as per sketch.
WE WILL USE  STONE BLOCK  AS A RECTANGULAR WEIGHT(50 kg.and 800 gram) AS CANNOT USE IRON BLOCK DUE TO MAGNETISM
Clearing your doubts.
(1)there is no need of taking springs as I just thought that spring will work as  a absorber of opposite force but in this system there is no need now.
(2)At first we will try this device with  single finger and take more fingers after development.
(3)we will take same quantity but but different size magnets and will attach with both 50 kilogram weight and 800 gram weight.
(4)The repelling force between 50 kilogram weight and 800 gram weight due to  equal polarity will work on 800 gram weight to inclined and repelling this small weight with high  force. This 800 gram weight will get back its position again due to Gravity.
(5)we will use a 3 volt toy motor as a external source to press the seesaw system in linear motion.
We will use a 'L' form crank and this crank will work to convert the rotatory motion of 3 volt motor into linear motion.
this 3 volt toy motor will attach with right arm of seesaw system as per sketch.
(6) We can use ' simple magnet coil' generator to generate electricity. and this generator will be attach with the wheel of 800 gram weight as per sketch . each 800 gram weight will have four wheel so we can attach four generators with each  wheels and thus we can attach more four generators with second no.800 gram weight.
(7)The seesaw system(50 kilogram) will be stated  on some height compare than track system(800 gram weight)  but distance between 50 kg weight and 800 gram weight will be very less so that the magnet of 50 kilogram weight could repel 800 gram weight.
MECHANISM:
when right arm of seesaw  which is attached with 3 volt motor  will be pressed by 3 volt toy motor  then this arm will come down and the 50 kilogram weight will work to repel the 800 gram weight with high force.  Due to repelling this 800 gram weight move fastly and generate electricity as generators are attached with the wheels of this 800 gram weight.
Now due to linear motion this arm will move up and second arm of seesaw system will come down and will work to repel its side 800 gram weight.
In this way both side arm of seesaw system will work to repel their side 800 gram weight by their turn.
I would like  to insist on some following points:
(A)
Each 800 gram weight will also have four simple magnet coil generators .Take this 800 gram weight as a measurement as its weight will be increased after attaching generators but this is not a problem .I took these weight only for your convenience so that you could understand easily this concept.
(B)The repelling force will not affect the movement of seesaw system and it will move in linear motion very easily with only 3 volt motor as due to repelling the 800 gram weight magnet will get further distance and there will no effect of equal repelling on this seesaw weight and  in that time this arm will be pulled up by 3 volt motor due to linear motion.
In this way this device will work I hope this time you will understand it completely .
Thank you Sir
Vikram
